Do you need a 10'1" tandem to move this load?
But I wouldn't trade the CAT for anything else. It'd help to have a longer wheelbase. Mine is 235"... I'd love to have 240" or 244" just to help with the weight distribution.
Watch my YouTube videos
Don't think you would get heavy on the steer, won't be any different than any other load when you get 34,000 on the drives. The shipper will back it on unless you are at a port. Watch the height if you put the front up on the step. Really should be a easy load.
I believe someone else mentioned it, but you need to make sure to throw a chain or strap across the blade. The same thing is true if you load a bulldozer. Excavators should have a strap or chain across the bucket.
Steers: 11,600 lbs Drivers: 12,300 lbs Trailer: 6,980 lbs Total empty: 30,900 lbs So, it looks like I can take 27,000 lbs on the trailer axles and 21,700 lb on the truck drives.
Thanks. I"ll buy those 3/8" chains and use four of those plus tie the bucket if it has one. I scaled the empty truck after fueling. Here's the axle weights:
Steers: 11,600 lbs Drivers: 12,300 lbs Trailer: 6,980 lbs So, it looks like I can take 27,000 lbs on the trailer axles and 21,700 lb on the truck drives. Please do yourself and the agent a favor and don't post the rate. It could come back and bite you in the butt.
This is the article
RUNNING PATRIOTIC CARGO: New military equipment RATE: $6-plus/mile (including fuel surcharge) HAULER: Brian and Marie Patrick, leased to Landstar SHIPPER: BAE, U.S. armed forces RECEIVER: Various military installations EQUIPMENT: 2007 Peterbilt 379 with lift axle and 2006 tri-axle Load King removable gooseneck with detachable fourth axle LOAD/UNLOAD: Typically under one hour, longer if tarping required Brian and Marie Patrick, of Chelsea, Mich., haul oversize, new equipment from manufacturer BAE Systems’ five facilities in Michigan, Ohio and Pennsylvania for the U.S. military. “There are 55 of us who do this,” Brian Patrick says of the core of Landstar’s specialized team delivering new Bradley fighting vehicles, MRAP military personnel carriers and other vehicles. Since they landed that niche with agents Doug and Nancy Cooper, out of Arkansas, after years hauling general military freight as well as arms, ammunition and explosives, they’ve increased their gross revenue, Brian says, by $100,000 a year while decreasing their gross miles. Their take-home is up at least $50,000. “We’re clearing $300,000 in the end,” he says. But making that kind of money comes with sacrifices, Brian says. “Our home time is very limited.” The road to success in the standard AA&E hauling arena starts with having a team operation. Other entry hurdles require significant carrier investment in satellite tracking equipment and hazmat-type levels ($5 million) of insurance, frequent background checks and DOT inspections. And unlike the rates in the Patricks’ specialized operation, say Duenweg, Mo.-based owner-operators David and Teresa Hill, leased to Landstar, typical AA&E freight averages less in revenue – between “$3 and $4 a mile, typically,” David says. Although quite high compared to some hauls, the rates the Hills were seeing fell off a bit in 2007. All the same, AA&E haulers are a select bunch, with about 30 carriers participating in the program nationwide, including in addition to Landstar and the Hills’ former carrier, Tri-State Motor Transit, sizable outfits like Mercer and Baggett. Most owner-operator teams approved are leased to carriers, but not all. However, team haulers looking to run AA&E on their own authority now need to establish a relationship with an armed-forces shipper to enter the program. The Patricks wouldn’t do anything else, says Brian. “You never drive at night,” he says. Plus: “An older gentleman who has a master sergeant’s stripes told me, ‘If you work for the government, they never run out of money.’ There’s always opportunity out there.” The best perk of the job is the gratitude of those who receive the equipment – “the latest, the greatest and the best that’s available,” Brian says. “When you see the soldiers’ faces who’ve got to use these things… I wouldn’t give it up for nothing.” -------------------------------------------------------------------------------- He gave it up, and had to sell his truck, "Loose lips sink ships" or "keep your pie hole shut" |
