Proper way to measure wheelbase
Old 01-01-2010, 09:29 AM
classictruckman's Avatar
This is the truck I'm looking at:
2006 PM 80027+J1204 Knuckle Boom 80 ton/m - 110' vertical reach - on 2006 International Paystar Ta-Ta & 22' Deck | Boom Trucks : Concrete Pump Trucks : Knuckle Booms : Knuckle Boom Cranes : Crane Truck : BIK Hydraulics Ltd.
It has a 304" wheelbase according to the crane dealer, but I think they measured from the center of the front steer axle to the center of the dead area between the drive axles and I think they should of measured from the center of the dead area between the steer axles to the center of the dead area of the drive axles.
Old 01-01-2010, 12:46 PM
Kranky's Avatar
Straight from the National Truck Equipment Association:
NTEA | Truck Equipment Glossary
Wheelbase (WB) Horizontal dimension from the center line of the front axle to the center line of the rear axle on a single-rear-axle truck chassis; measured from the center line of the front axle to the center line mid-way between the axles on a tandem-rear-axle truck chassis.
:smokin:
Old 01-01-2010, 02:08 PM
That still doesn't answer my question, I'm concerned about the place to measure from on a front(steer) tandem axle. Look at the truck on the webpage I listed.
Old 01-02-2010, 12:24 AM
Kranky's Avatar
I would say measure it the same way, from the centerline of the front steer axle to the midpoint between the drive tandems.
Old 01-02-2010, 01:05 PM
But would a tandem steer have a smaller turning radius than a truck withsingle steer, a similar wheel cut and wheel base?
Old 01-14-2010, 03:38 AM
Default just fyi
If you are measuring the wheel base for weight, you measure from the
center of the first axle (tractor) to center of last axle (trailer) and round the number up or
down to the nearest foot. Example; 65'7" would be 66 feet and 65'5" would be
65 feet.
Thanks for the question. Hope this helps.
Sr. Trooper Monty Dial (Ret.)
Ol’ Blue, USA
P.O. Box 4444
Van Nuys, CA 91412-4444
Old 01-16-2010, 12:56 AM
Kranky's Avatar
65 feet.
Ol’ Blue, USA
P.O. Box 4444
That's not wheelbase, that's "spread" for calculating permissible axle weights and GVW or GCW.
Old 01-18-2010, 02:43 AM
I'm just wondering if it would be better to buy a tridrive or a tandem-tandem, I don't do much highway driving(spend more time on cottage roads meant for cars) so manuverability is very important to me and if a tandem-tandem steers tighter because the wheelbase is actually shorter then that would likely be the better truck.
Old 01-22-2010, 02:04 AM
