Old 10-20-2007, 02:10 AM
Papa Rick's Avatar
Default Down To 4.4 MPG??????
Checked my mpg tonight and it is down to 4.4mpg???? Man what the heck is happening????
Went back to my old vendor and it didn't make a difference, changed the air filters, didn't make a difference. (they needed changing)
Called KW Dealership and they told me the only thing they knew it might be is overhead run. I asked them would this make it loose 1 1/2 mpg and they said never heard of it doing that much.
It isn't skipping or loosing power. I ran 327 miles today and it took 73 gal, which comes out to 4.47
Should the Dealership be able to plug it up to the computer and find something out?
ANYONE HAVE ANY SUGGESTIONS???????
Old 10-20-2007, 02:18 AM
They can connect to the trucks computer and see how the injectors are performing, see if there are any codes and a number of other things about the truck. If you have changed the filers and are still getting poor fuel mileage that would be my next step. It should not cost much to have it checked. 4.4 is a huge drop. :shock:
Old 10-20-2007, 02:23 AM
Papa Rick's Avatar
Thanks GMAN that is what I thought. I didn't want them just to do the overhead until they ran the check on the computer. The drop from 6 to 4.4 for 327 miles cost me $ 55.48 more. In one week of 2000 miles the difference is $362.42 WOW that hurt!
Old 10-20-2007, 02:48 AM
I would have the cpu checked before having the overhead run. Any of the major truck or engine dealers can check it for you. Southeast Diesel in Chattanooga can also check it. It only takes a few minutes and would probably cost less than the difference in what you spend on fuel on that 327 miles.
Old 10-20-2007, 01:43 PM
Bobby's Avatar
Is this a single turbo C15... or twin turbo ?
Old 10-20-2007, 11:29 PM
Sonny Pruitt's Avatar
buy fuel somewhere else
see if there is a difference
(may be bad fuel or someone tampering with the pump?)
dump some diesel clean in to boost cetane
see if that makes a dif
are you sure your odometer is accurate
lock your fuel cap
Old 10-21-2007, 03:22 AM
Papa Rick's Avatar
Took the Truck to the shop today and they ran the computer on it and nothing showed up. The fuel mileage showed 5.46 avg. I told them it was above that when I bought it 9-28-07, and that I had been avg 6.0.
They reset the computer (Cost $90.00 Labor to do this) Guess they have to make money, but not this much!
Requested they take an oil sample and send it off and see what it tells me if anything.
Service MGR said they could run overhead, but he would run it 1 more week with the computer reset and see if it shows the 4.4 avg.
Was told that I could have got some ultra low sulphar fuel, and this could cause the big drop.
Where I fuel most of the time has the low sulfur sign but not ultra low. The place that I got fuel at and it started dropping, I am not sure if it is ultra or not, but will find out.
Bobby Posted: Sat Oct 20, 2007 7:43 am Post subject:
Single Turbo C-15
Sonny Pruitt Posted: Sat Oct 20, 2007 5:29 pm Post subject:
lock your fuel cap
Odometer is correct as we on a pay per ton by mile, so the places I go have distances already set and I check it to make sure I am getting my pay right.
If I got some bad fuel could it cause the following on mpg. Starting on
10-14 I bought fuel at a different place. Before that here is the fuel mileage avg:
10-3-7 411 miles 72.28 gal 5.68mpg
10-8-7 477 miles 81.17 gal 5.87 mpg
10-13-7 491 miles 83.15 gal 5.90 mpg
Switched vendors
10-14-7 666 miles 116.02 gal 5.74 mpg
10-15-7 655 miles 119.00 gal 5.50 mpg
10-16-7 654 miles 125.70 gal 5.20 mpg
Switched back to original vendor I have used for the past 6 months
10-18-7 562 miles 106.99 gal 5.25 mpg
10-19-7 327 miles 73.02 gal 4.48 mpg
Hope this will turn around soon!
Anyone have any suggestions that have not already been posted, I WOULD greatly apprecaite it very much.
Old 10-21-2007, 03:28 AM
Blind Driver's Avatar
I'll throw something in here:
Brakes sticking, everything lubed? Something might be dragging...somewhere.
Has a compression test been done on the engine? Hopefully you won't find anything excessive in the oil analysis.
Old 10-21-2007, 12:25 PM
Papa Rick's Avatar
Blind Driver Posted: Sat Oct 20, 2007 9:28 pm Post subject:
Checked for anything sticking, just had the truck serviced less than 6000 back and ran dyno on it same time, nothing showed up. Had the oil checked when truck was serviced and nothing showed up.
Old 10-21-2007, 01:09 PM
Well now, this is quite a dilemma. Perhaps it is something as simple as your fuel. It seems odd that your fuel mileage would be affected that much. :?
