Old 09-29-2007, 05:51 PM
ISMAR132's Avatar
Default DROPDECK AXEL WEIGHT LIMIT
WHAT IS THE LEGAL WEIGH LIMIT ON REAR AXELS OF A SPREAD AXEL DROP DECK?
WITH TIRE SIZE 255/70R-22.5
Old 09-29-2007, 06:13 PM
20,000 pounds per axle without permits.
Old 09-29-2007, 06:54 PM
ISMAR132's Avatar
SO IT WILL THE SAME AS A FLAT BED
EVENTHOUHG TIRE SIZE IS DIFFERENT.
Old 09-29-2007, 07:07 PM
ISMAR132's Avatar
THANKS FOR THE INPUT GMAN.
I ALLREADY HAVE A LOAN APROVED AND NEED AS MUCH INFORMATION AS POSSIBLE TO CHOOSE BETWEEN A FLATBED AND A STEP DECK.
I HAVE EXPERIENCE IN FLAT BED BUT NEVER HAUL A DROP DECK.
ANY IMPUT WILL BE APRECIATED.
Old 09-29-2007, 07:30 PM
Axle weights are the same regardless of the type of trailer. Keep in mind that if you run Canada, you may not be legal in some provinces with a 10'1" spread axle.
By the way, that is the same size tire as I wear on my step deck. What brand do you plan on buying?
Old 09-29-2007, 11:10 PM
ISMAR132's Avatar
IS A 1995 TRAIL KING 48'X102' $13,500
Old 09-30-2007, 03:47 AM
rank's Avatar
What GMAN said.
I think you'll find if you take the tire weight rating off the sidewall and multiply by 8 tires on the 2 rear axles, the result exceeds 40,000 lbs. If for some reason your tires add up to less than 40,000 lbs, some DOT guy may have an issue (if he notices).
Old 09-30-2007, 04:22 AM
pigrider's Avatar
I load trucks for a living right now and a lot of guys are going to drop decks! One told me last night me has made more money this year with his drop deck! When I retire in 90 days I will buy a drop deck (with load levelers).
"JUST SAY NO!!!! To Cheap Freight!!"
"Big Red One" , 3rd ID, 82nd Airborne, Recondo, Jumpmaster, & Drill Sergeant
OOIDA
Old 09-30-2007, 04:27 AM
rank's Avatar
I've been seing alot more on the road. Maybe people have been reading my posts here. I should shut up.
Old 09-30-2007, 08:33 PM
Graymist's Avatar
What advantages does a drop-deck hold over a regular flatbed ?
