Knock Knock Clatter- what do I tell my mechanic? Help!
Hey Guys... Just got my truck out of the shop Friday. I had the bottom bearings replaced (main and rod), new oil pump, new front main seal, and a few odds and ends. They also turned my truck's horsepower up from 330-430 split HP to fixed 470 h.p.. Engine is an N14 Cummins...
When I picked it up, it sounded "different"... a little more clatter at idle. Driving it the 125 miles home, on about 5 occasions, I got a knocking sound. Mostly when climbing hills (running empty). It would knock varying from a little to a lot, then the noise would go away. Oil pressure is fine, truck runs fine, except for this.
I had an overhead done a couple months ago. The truck ran OK when I took it in, except for the chronic low oil pressure I have had. They seem to have fixed that problem, but now a new problem! :x
I am guessing maybe an injector going bad? :shock: I am no mechanic... some of you who have ideas, please offer them! I won't be back on the computer until Monday, but will check your replies before calling the mechanic.
Thanks fellers............ 8)
"It is not the critic who counts,
not the man who points out how the strong man stumbled,
or where the doer of deeds could have done better.
The credit belongs to the man who is actually in the arena;
whose face is marred by the dust and sweat and blood;
who strives valiantly; who errs and comes short again and again;
who knows the great enthusiasms,
the great devotions and spends himself in a worthy course;
who at the best, knows in the end the triumph of high achievement,
and who, at worst, if he fails, at least fails while daring greatly;
so that his place shall never be with those cold and timid souls
who know neither victory or defeat."
Theodore Roosevelt
