Old 05-01-2010, 10:19 PM
robertt's Avatar
Default Oil Spill
I don't know how the refining process works with oil, but isn't "oil" mixed with salt water when it first comes out of the ground? Wouldn't the oil sheen that you see in the pictures from the Gulf be just that, a sheen? Is what is going to wash up on shore going to be "thick" like what comes out of an oil jug or a finer product? I was just wondering because we have "salt water" trucks around here that thats all they do is collect salt water from the tanks out here at the remote sites where it has been separated from the "oil" part of it.
I WOULD RATHER BE HATED FOR WHO I AM, THAN LOVED FOR WHO I AM NOT
Old 05-02-2010, 10:30 AM
You have to keep in mind that as it comes out of the ground, it also contains all of the by-products that are taken out during the refining process. Back, when I was aboard ship in the Navy, the fuel was a thick, gooey mess that was hardly refined at all. It also had to be pre-heated so that it would burn in the boilers.
200 years ago, the wells were not for oil, but for salt. They'd drill a well, start pumping the salt water out, and it would start getting contaminated with oil. (That was back before oil became black gold) So, it really is no surprise that salt water would be mixed in with the crude oil. And, they can't simply drain off the water because it's contaminated with the oil, so it must be disposed of properly.
But, if you think about it, coming out of the ground, it contains tar, your axle grease, and all the petro-chemicals. I would suggest that you can expect a pretty serious MESS from it all. When it hits the beach, you can expect the sand to be covered with a thick, gooey, black mess that sticks to anything it touches. And, the clean up will not be cheap. It will also do quite a number on fishing in the gulf. I can't say I mind the fact that the number of sharks may be reduced, but it will affect every species in the water. There are chemicals that are toxic, and mix with the water (like the components for anti-freeze) that will have an effect on every creature in the sea. Any birds that get their food from the sea will, very likely, ingest it along with all the poisons it contains. Quite an impact on the environment.
Old 05-02-2010, 10:59 AM
They were talking about setting it on fire before it reached shore, but the EPA didn't want them to do it. So now we will have a much worse disaster on our hands. I think that they should have set it on fire and then asked permission. Much or all of this might have been avoided.
Old 05-02-2010, 12:56 PM
They are mainly worried about is not just LA now but the whole eastern seaboard. The rig was sitting right at a current of warm water(Gulf Stream) that runs down around the tip of Florida and back up the eastern seaboard in the Atlantic all the way to Maine. If that current picks up this oil the entire world could be in trouble. Right now it's naturally contained in the Gulf, let it get out into open ocean and you got a mammouth problem.
Controlled burns are being done but it's a waste of time now, should have set it alight sooner or left the oil rig burning instead of putting it out. I hate that everyone is jumping BP for not doing more sooner. They or anyone else had no idea how bad it was or was going to be. They got a robot down there ASAP to give them a look at the valve and to see if they could remotely get it closed. When they saw what was going on they knew they had an even bigger problem and started getting to work which takes time. We have Monday Morning QB's running around saying they could have done more sooner though................
Old 05-02-2010, 02:04 PM
robertt's Avatar
As they say around here, it's easier to ask for forgivness than it is to ask for permission.
I guess WW, if I had of thought about it, the Exxon Valdez was pretty much the same thing. It had just come out of the ground and wasn't refined so it will be pretty much the same thing.
I had also heard as Mr. Ford said, that they are worried about it getting caught up in the Gulf Stream and polluting the whole east coast, from Fla to Maine. What a mess.
Old 05-02-2010, 06:51 PM
There were a lot of mistakes made that resulted in the coming "Mess".
The BOP (Blow Out Preventer) was disabled by something. Most likely that something is a drill stem "collar" (the "connection" between 2 sections of drill pipe). The "Blind Ram" on a BOP is designed to shear drill pipe and casing, in a "Blow Out" event. However, the Blind Ram is limited in it's mechanical function-ability. "Brute Force" is used for shearing, but the BOP cannot generate enough brute force to shear through the collars of drill pipe or to shear through "drill collars" (the thickest, heaviest pipe sections, located at the bottom of a drill string).
Drill string - Wikipedia, the free encyclopedia
The Blinds can shear through some casing collars, dependant on the "weight" of those collars. Some extremely heavy casings can not be sheared.
Here is a link to definitions of "terms" being thrown out by various news media types and industry experts.
http://oilgasglossary.com/casing.html
I got to talk with my best friend last night. He was on a unit 45 miles southwest of the Horizon. He rode over on a helicopter that flew off the unit he was working on, and went out to the Horizon to do an aerial survey, mid-day on wednesday after the explosion. His video and still photo's are at corporate offices in Houston. The company he works for was the operator of the "Mud System" on Horizon.
My friend's "conjectures" as to what happened;
First. It is fact that Halliburton had just completed a "Plug Back", in preparation of Horizon being disconnected from the find and repositioned onto another drill site. That is a fact.
Second. This well is a "Discovery" well. BP had no intention of the "Production Volumes" being public knowledge at this time. That is a fact.
Third. The fire was extinguished when the Horizon flipped over and sank. That also is a fact.
Unfortunately.....by flipping and sinking, the shear weight of the entire Horizon unit, caused BOP issues totally separate from whatever issues were in place, at the time of the first and second explosions. This was a "double" explosive event. The second explosion and the resulting fire occurred approximately 3 hours after the first. The eleven people whom died, were working to correct or repair the conditions that caused the first explosion.
Now the "conjectures" come into play.
The main...and most likely conjecture. The rig lost track of the collar locations, as the string was being worked. When rig crews are working a "string", they strap every stand or joint run into the well bore, to maintain an accurate placement of collar location. This is done to prevent a collar being placed in the "Blind Ram" point.
Whether on land or offshore, drill pipe strings are "stood back" in 3 joint sections, as they are pulled out of the "well bore". When those strings are run back into the well bore, they are re-attached in exactly the same pattern that they were stood back. The last string out of the hole is the first string to go back into the hole.
[ Back when I worked in the oilfield, everything that was run, was strapped. Every time. Every few strings, operations were stopped, so that tally books could be compared, and figures could be double checked. The idea was to prevent BOP's being blocked by collars, but also.......to be accurate in the specific placement of the drill bit or other "down hole" tools. Usually tally books were being kept by The "Company Man", the "Tool Pusher" (the man whom was in direct charge of the drill rig), the "Tool Man" (the person whom was in charge of the drill bit or other "down hole tools" such as a "bridge plug", a "packer", casing "floats", etc) and usually either a "Mud Man" or a "Cementer".
That was in the 70's and 80's....when I did this type of work. I was a "Cementer" and a "Safety Man". That ended when I changed jobs 23 years ago.
Things could be done a little differently...but not that differently. They still have to keep track of tools and collar locations. ]
Now.....The main conjecture....as to the "Cause" of the blow out.
First conjecture alludes to the "Bridge Plug" and it's failure. If the bridge plug did not hold it's position or was improperly set, it would not do its job, which is to prevent bottom hole or production zone, fluids and gases leaking by.
Second conjecture alludes to substandard cement being spotted above the bridge plug. "Substandard" could mean anything. The cement itself could have been contaminated in some manner and did not "setup" as it should have. There should have been at least 2 cement plugs set on top of the bridge plug (which is a mechanical device).
Third conjecture alludes to the drilling mud itself, being to thin and unable to control the "kick" when the blow out started. Drilling mud serves three purposes. First it lubricates drill bits. Second, it transports drill shavings. Third...it's density controls "Bottom hole" fluids and pressures from the production zone. In this case the mud may not have been heavy enough to stop a blow out.
The final observation........there was no attention being paid to "returns". Returns are the fluid discharge coming from the well while work is being performed. Regardless of the work being done, there should have been "Static fluid" at the top BOP or "Stack"(yes...there was a BOP directly beneath the drill floor). While working a string, it is imperative that fluid be "static" (fluid that is holding in place, with the exception of annular volume created by removal of pipe and tools) in the well bore.
If the bridge plug and cement plugs had been properly placed and were doing their jobs, the well would have been "static". The only thing the rig crew on duty would have needed to do, to maintain fluid at the top of the stack, was to attach the "Kelly" every so many stands or pipes laid down, and re-circulate the well bore.
If the fluid is being sucked into the well bore, then the well is on a "vacuum" and things are done very quickly to plug the well bore and stop the vacuum. The rig crew would use things such as cellophane chips' cotton seed hulls or crushed walnut shells, to thicken the drilling mud and plug up the formation which is on a vacuum. That was not the case for the Horizon.
In this case.....the fluid was being forced out of the well bore. Those fluid returns should have been immediately noted, and the stack should have been closed in and the Kelly reattached to the drill string, in preparation of controlling the approaching "Kick". In my friends opinion...and in my opinion...this was where the rig crew dropped the ball. They were not paying attention to the monitors and did not see the "kick" coming. Bad mistake.
In the case of this well, the last cement plug would have been a "brittle" plug, set at about 150 to 200 feet below the seafloor BOP, which would have remained in place when the Horizon was moved. A brittle plug would have been set as a precaution to prevent the GOM waters from leaking past the BOP assembly before a production unit was in place. A brittle plug is used at the surface because it drills out easily and there is little risk in a drill bit "sidetracking" out of the well bore at that point.
At the time of the first explosive event, the rig may have been at the point where they were laying down the bottom hole assembly........which would account for the BOP being blocked. To set that last plug, the bottom hole assembly is laid down, then the string needed to set the last plug is run back into the well bore. After the plug was in place, the crew would have then laid down that last string of pipe, in preparation of disconnecting from the stack and moving to the next drill site.
Because every one involved is most likely dead and with the video record of the work being done, also destroyed by the fire and sinking of the unit........BP, Transocean, the Federal government and it's entities.......and all of us..........are left to conjecture.
was I articulate enough in explaining what little I know?
Also! Something that the "Enviromental Lobby" is not going to be bringing to the forefront, as it pertains to this spill and the mess that it will create.
After the Exxon Valdez mess in Alaska, Prince William Sound and the Cook Inlet, as well as the surrounding Kenai Peninsula area, fish, crab and mammal populations rebounded at before unseen rates. The fishing in Prince William Sound and Cook Inlet is better now (and was two years after the spill) than it had been in the previous forty years.
Crude Oil is an organic compound. It is composed of decayed matter such as leaves, grass, trees and mammals(re: dinosaurs). Yes...It is visually unappealing and it is hard to clean off. But in the end..."Crude Oil" is as natural as the water we drink and the air we breath.
As with Prince William Sound, natural will clean herself up and life will go on.
It is what man does with crude oil that is harmful to life. There is nothing any of US did in the past, in the present, or will do in the future, that was not or is not, the result of crude oil and it's uses. The computer that you read this with, is proof of that. :thumbsup:
Old 05-02-2010, 06:55 PM
That was "Bunker Fuel" and it was the final waste from the refining process. There are still ships that burn "Bunker". They switch from diesel fuel to bunker once they have reached International waters!
Bunker is also used for fuel at power plants to a degree. There it is cut with diesel.
Old 05-02-2010, 09:09 PM
robertt's Avatar
[quote=Orangetxguy]was I articulate enough in explaining what little I know?[/quote]
:eek2::eek2::eek2::eek2:
Not only was it articulate enough, I think I have enough information now that I think I'll go start my own oil company. Very interesting. :thumbsup:
Old 05-02-2010, 09:33 PM
[quote=robertt;480149]
:rofl: If you have that much money...Why bother? Move to Tahiti and live the good life....NO WORRIES !!
Otherwise....spend your money and let BP buy you out!
:clap: :clap: :clap:
Old 05-06-2010, 06:33 PM
Bump!
Have yall heard how they are doing?
Last I heard, they were going to try to put a 'dome' on top of the oil well (etc) and see if they can contain the leak. :hellno:
Seems like to me it would be easier to shut it off from pumping and go down there and fix it. ...... Or maybe that's what they tried?
I think I heard that they are leaking out 5,000 barrels a day? I can't imagine them leaking that much oil every day. :hellno:
Last edited by Jackrabbit379; 05-06-2010 at 06:34 PM. Reason: Forgot to spell check. Ughhh.
