Another Power Inverter ????
Old 08-25-2007, 03:56 PM
fireman932003's Avatar
10-4. I will call you in the am if that is ok. I leave out around noon tomorrow.
Old 08-28-2007, 10:40 PM
Cluggy619's Avatar
A cleark at a truckstop told me this simple rule when looking for a power inverter.
The amount of volts required X the amps of the thing you want to run = the wattage you need.
Example: 120 volts X 3 amps = 360 watts needed, so you would need a 400 watt pover inverter for that one item.
Hope this helps. :wink:
Anyone can learn to drive a truck. Few become truck drivers.
Deja moo. It's when you feel you have heard this BS before.
