Deisel Fuel smell out of clothes?
Got a few clothes that were pretty well covered with deisel fuel...don't ask
ops: Is there anything that will get the deisel smell out, tried everything I can think of and can't afford to keep tossing clothes!!!Thanks,
Getting any smell out is an easy 3 step process
1) Find Skunk 2) Scare Skunk 3) Get sprayed Helps to have a lot of tomato juice handy before step 1! Seriously though, I use ERA laundry detergent and have not had a problem. Seriously soaked may take 2 washings though.
REMEMBER, guns don't kill! It's the jealous husband that comes home early!
And having diesel smelling clothes is a problem because ____________?
IMO diesel fuel smells better than the finest perfume, second only to the aroma of diesel exhaust. :P
Downey Fabric softner is great for nasty smells, dont know about diesel but sure got the skunk smell off of a dog. Wet a couple of face clothes and toss em around the cab...gets rid of the smell of feet and butt pretty good as well if your the type to stretch those showers an extra day. Pretty handy when you have to pick up a truck or do some slip seating.
IMO, yoopr nailed it. A good heavy dose of vinegar will do wonders or you can subsitute that with a "good" citrus cleaner, but vinegar works better. Double up on the detergent and use fabric softener also. You may have to wash them a couple of times, but it will get most if not all of the smell out.
If it's a stain spot, diesel, oil or similar, spray the spot thoroughly with WD-40 and then rub in hand cleaner just before you put it in the wash. A couple of squirts of liquid hand cleaner in the wash also is better than any spray and wash on the market. The WD-40 helps to loosen up the stain, as JR said "Boy, oil and water don't mix", and the hand cleaner will wash it away. Growing up on a farm I saw my mom us this remedy a million times and it worked like a charm. Have done it a million times myself and it still works.
The opinions expressed are those of the author's only. They do not represent the views of CAD or of the other members of CAD... |
