-   -   24.5 vs 22.5 tires (https://www.classadrivers.com/forum/truck-maintenance/29469-24-5-vs-22-5-tires.html)
solo379 09-13-2007 01:42 PM
Originally Posted by special k
I suggest you go talk to an actual tire rep about rolling resistance
Did you do it?
allan5oh 09-13-2007 04:04 PM
Allan there very few things in life that are 100% right or wrong. I suggest you go talk to an actual tire rep about rolling resistance before you reject it out of hand.
You're joking right?
You realize that michelin x-ones have the lowest profile of any tire? There's a reason they did that.
You probably believe everything truck salesmen tell you as well.
Look up XDA energies. They're the most efficient conventional tire out there. They're only available in low pro 22.5. There's a reason for that too.
geomon 09-13-2007 04:20 PM
Lo profile tires lower rolling resistance by having less sidewall flex. Thus less energy is lost to that...hence less rolling resistance.
I don't think it has anything to do with the number of times it rotates. It could rotate 5 rpm or 5,ooo and the same surface area of tire is still on the ground.
solo379 09-13-2007 04:34 PM
Guys, 24.5 is low pro too, so that's not a valid point. I don't have a "hard data" on this, just an opinion. And anyhow, difference on the same model 22.5 and 24.5 tires is very marginal! :roll:
allan5oh 09-14-2007 09:20 AM
Look at it this way, how many fleets or trailers run 24.5 tires?
solo379 09-14-2007 12:24 PM
May be that will answer your question! I guess, we were wrong! :roll:
http://www.bridgestonetrucktires.com...r_specs.asp#1a
dteam270 09-14-2007 12:51 PM
Good post solo.
allan5oh 09-14-2007 01:32 PM
Interesting. I was always under the impression that 22.5's had lower resistance, smaller contact patch, smaller sidewall.
I'd love to see that SAE test.
special k 09-14-2007 01:40 PM
I guess I wasn't joking Allan. 24.5's come in high and low profiles just like 22.5's. 90% of the reasons fleets use 22.5's is to save money when buying tires and usually there is more demand for 22.5 casings to be retreaded. The other reason is that they want to max out on cubes in vans and a taller tire raises the van up and could cost them space in the van.
allan5oh 09-14-2007 01:43 PM
Sure, but the contact patch for a 22.5 lo pro will be smaller then a 24.5 lo pro tire of the same width.
I'm REALLY surprised if a 24.5 tire is less resistant.
