I guess you're right!Originally Posted by allan5oh
Then he's not legal in Canada regardless of how many he has..
Heavy vehicles shall be transported in accordance with this section.
(2) Accessory equipment on a heavy vehicle, including a hydraulic shovel, shall be completely lowered and secured to the vehicle unless:
(a) the accessory equipment can only move vertically;
(b) accessory equipment that can pivot, tilt or move sideways is blocked or immobilized by the
transporting vehicle’s structure or by a blocking or securement mechanism built into the
transported vehicle.
(3) Articulated vehicles shall be restrained in a manner that prevents articulation while the vehicle is on a highway.
(4) Despite section 22, a heavy vehicle with crawler tracks or wheels shall be restrained against moving sideways, forward, rearward and vertically by at least 4 tiedowns,
(a) each with a working load limit of at least 2 268 kilograms, and
(b) each attached, as close as practical, at the front and rear of the vehicle or to mounting points on the vehicle that are specifically designed for that purpose.
I wonder why US DOT 'experts' couldn't come up with the same WLL recommendation of 2,268 KG or 5,000 lb per chain. It makes sense. BTW, this is the first time I see this Canadian document. Thanks, Alan. Now I'll know. I'll keep my 5/16 chains but will get at least 4 heavy duty ones for corner tiedowns. Then I should be okay both in Canada and US. But I think my stake pockets are only rated for 5,500. I usually use them with heavy stuff (wrap the chain around all the way from one side, then under the pocket and hook on the other side of the pocket). I feel better when a chain goes from one side of the trailer via an eyelet on the machine to the OTHER side of my trailer. I don't have in-floor tiedowns.
