Based on the original load numbers - IF you could have slid the 5th wheel to put another 1,500 lbs on the steers (and that's a BIG IF - depending on the dynamics of the load) that would give you another 2,570 you could have shifted onto the drives by sliding the tandems BACK. With 36,380 on the original weight - that's about 8-10 holes you would have had to slide - probably maxing your slides and giving you a rig that would likely run over EVERY OTHER CURB you came across today.
You probably could have gotten your axle gross's close to "in the ballpark" by sliding your rears all the way back - but the few hundred lbs afforded by a sliding 5th, would probably had allowed you to shift enough to get drive/trailers within spec.
Ever wight your tractor to see what it's gross is - along with an unloaded trailer? Probably worth a scale ticket out of pocket, so you can tell at at glance by looking at the BOL, whether or not you're going to need a trip back to the shipper after scaling - or not.
Thanks again, for the LEARNING EXPERIENCE. That's just ONE MORE THING I'll be cognizant of - BEFORE I even graduate school and it the road myself...
Rick
Every driver should know his empty weight, regardless of what they pull.Originally Posted by SickRick
I don;t understand why shippers can't fathom this (and they likely CAN - but just don't give a rats patoot). X Pallet has y numbers of cases at z lbs per case X x Y x Z + weight of wooden pallet = weight per pallet loaded (W). Truck can handle a gross load of - T, so T/W= number of loaded pallets. Like they DON'T KNOW how many you can handle? I suspect palletized cases of bottled water are single stacked only. I mean - unless you've got a ton or so of "powdered contraband" in a false floor - it's NOT ROCKET SCIENCE.Based on the original load numbers - IF you could have slid the 5th wheel to put another 1,500 lbs on the steers (and that's a BIG IF - depending on the dynamics of the load) that would give you another 2,570 you could have shifted onto the drives by sliding the tandems BACK. With 36,380 on the original weight - that's about 8-10 holes you would have had to slide - probably maxing your slides and giving you a rig that would likely run over EVERY OTHER CURB you came across today.
Rick
