Originally Posted by unkut2003
Originally Posted by GMAN
When I go for my physical they do a drug test. I get the results on the spot. This place does a lot of DOT physicals. The reason it can take longer with some is due to them sending them off to a lab rather than doing it locally. If they send it off it usually takes 2-4 days.
Yes, yur absolutely correct! They did a "split-specimine"??? Said it would be done by Monday/Tuesday.
Unkut: ALL DOT tests are "split-specimen." If your FIRST one wasn't, well... that might be part of it being a NON DOT. Your boss sounds like a real flake! Doesn't know testing OR logbook requirements?? :shock:
However.... it shouldn't take over a week! I don't want to scare you while you're already concerned..... but I noticed on another thread where you mentioned your CODEINE for your migraines. If I'm not mistaken, this might still show on your tests, and you MAY have to get a doctor to talk to the MRO. I would stay on top of this, if I were you! Does your employer KNOW you take this med??
If the additional time is due to them testing the "split," there may be more afoot. YOU are supposed to request that, if you want it. Costs about 150 bucks extra (I think.) If THEY are doing it without your consent.... more is afoot.
Another question..... did you list the Codeine meds on your DOT physical?? I sure HOPE so!
