Originally Posted by Vegas
Anyone have insight/opinions about the Dollar General, Dollar Tree & Wal-Mart dedicated accounts US Xpress has. Do they allow teams on these runs & which/if any would you consider the best choice among the three? Also can someone explain the difference between the "auto-shift" trucks USX has & a typical automatic transmission?
dollar gen, are solo only runs at between 200ml & 350 with 1-4 stops each and return. most runs take 14hr + 10hr break and 4hr back. YOU hand unload each stopto the back of the trailer (most stores don't have loading docks) you park by the side door. you get stop pay for each stop & unload pay. i've done then didn't like it but for 1 trip 237ml i got $374.
dollar tree is about the same. not sure about wal-mart. we also have TJMAX and that is team only but you HAVE to stay out for 6 weeks at a time. some drivers like um some don't.
an automatic (like you have in a car) use a turque-converter with wet clutch's and alot of "soft" parts (the soft parts are the parts replaced in a rebuild) and has 2-6 speeds
an auto-shift (call auto-shift, freedomline, ultralshift or i-shift) is a standerd transmission (9,10,11,13,14,15 or 18 speed) with a standerd clutch or air clutch( no pedal ) with a computer and a air shifter. the computer floots the gears the same as you do you just don't have a shift lever. the computer does all the upshifting and ALL the downshifting automatic's DON"T downshift. (if you are driving your car at 55mph and slow to a stop you will notice that the transmission doesn't downshift) doing the same thing in a truck with an auto-shift you will feel it do each downshift.
also an automatic transmission waste 10-20% of your horsepower (that's way a car with a stick get better mpg than an auto)
an auto-shift (usx use 10speed auto-shift) get the same (or better)mpg as a standerd 10speed (the computer can be set for mpg or hp) and you can override it by going manual and up or down shifting as needed
also in manual it WILL NOT let you go to a gear the will over or under rev the motor not like a car that will let you be going down the road at 70mph and if you shift into 2nd.........!!! if you try it in an auto-shift all it will do is beep at you.
what is funny about the auto-shift is when it misses a shift (we all miss one now and then) it's funny to here the truck do a gear recovery rev, rev, rev click, to good side is you can always keep BOTH hands on the wheel and you don't have to try to turn at the corner looking at the cars and change gears at the same time. or the lite turns green as you are drinking you coffee and you have to set your cup down to shift.
i can driver both the wife can driver both but she had a dicie knee so she realy likes driving the auto better. at the end of the day driving an auto-shift you just feel better (more rested) i won't even go it to how nice it is in LA, Atlanta, Chicago, the NE..
