-   -   Split sleeper berth question (https://www.classadrivers.com/forum/rules-regulations-dac-oh-my/25023-split-sleeper-berth-question.html)
mike3fan 02-21-2007 03:25 PM
I drive for 5 hours after a 10 hour break,get to shipper and go into sleeper berth for 2 hours waiting for appt.,on duty not driving for 2 hrs loading and then go into sleeper berth for 8 more hours,how many hours can I drive?
Here is my thoughts,since you usually take the time driving between the split sleeper berths and subtract from 11 and that gives you what you can drive I think I have the full 11hrs available,thoughts?
BanditsCousin 02-21-2007 03:34 PM
Re: Split sleeper berth question
You still have 9 hours to be used for "on duty" or 6 hours MORE drive time and 3 hrs "on duty". Trim your load time an hour if possible, if spent in the sleeper (napping, reading a magazine, watching TV, etc).
BanditsCousin 02-21-2007 03:35 PM
The split sleeper berth stops the clock, it doesn't extend it. The minimum is 2 hrs to split the sleeper berth, but is not limited to it. Its a good idea to log more than the remaining balance of needed sleeper berth time to make the logs look good. :wink:
Rev.Vassago 02-21-2007 03:49 PM
Nope. The 14 hour clock started when he began driving the 5 hours.
5 driving
+ 2 waiting
+ 2 unloding
__________
9 hours into the 14 hour clock
You can drive another 5 hours before you have to stop driving for an additional 2 hours. At that point, you have another 6 hours drivng time available to you.
Once you begin splitting your sleeper berth time, the only thing that will get you off of it is a full 10 hours off duty or sleeper berth.
BanditsCousin 02-21-2007 03:54 PM
Rev, he went into the sleeper for 2 hrs waiting (I'm assuming he logged it in the sleeper). He did spend 2 hrs "on duty" during the load (which I assume is logged as on-duty).
5 hrs (driving)
2 hrs (loading-on duty)
2 hrs (sleeper berth-waiting to be loaded)
___________________
7 hrs worked
remaining hours- 14 -7 = 7hrs (6 can be used for driving)
If he "trimmed" the load time on duty, he could free up some more time, or bank it for the rest of the week :wink:
edit: he does not have 9 more hours, as stated originally stated. I dunno where or how i got that figure :oops:
Rev.Vassago 02-21-2007 04:15 PM
5 hrs (driving)
___________________
7 hrs worked
The 14 hour clock DOES NOT STOP for that 2 hours he spent in the sleeper berth. The only thing that stops the 14 hour clock is 8 hours or more in the sleeper berth. Therefore, it must be counted in the 14 hour clock:
5 driving
2 sleeper
2 unloading
_________
9 hours used up on the 14 hour clock.
After the 8 hours in the sleeper berth, he has 5 hours remaining before the 14 hour clock expires, which can be spent driving. At that point, he must stop for 2 hours:
5 driving
2 sleeper
_______
7 hours used up on the 14 hour clock.
At that point, he can drive an additional 6 hours, at which point the 11 hour clock is used up. He must then stop for AT LEAST 8 hours before he can drive again.
Your mistake, BC, is that you aren't counting the 2 hours sleeper berth in the 14 hour clock. ANYTHING under 8 hours counts towards the 14 hour clock.
BanditsCousin 02-21-2007 04:19 PM
I've bnever been hit with a violaton for the 2 hr rule- i learned it from dad. I do it all the time, in fact.
I've extended my day of times by logging 2 hours in the sleeper, not exceeding 14 hrs total from my initial pre-trip, but ALWAYS catching up with 8+hrs of sleeper birth at the end of 14 hrs.
Must be a United thing? I blame it on Mayflower :lol:
BanditsCousin 02-21-2007 04:20 PM
Rev, we are both wrong.
We need Dawn to set us straight!!! :lol: :lol:
Rev.Vassago 02-21-2007 04:28 PM
Dad was wrong. Anything under 8 hours doesn't stop the 14 hour clock. I just drew it out on a log to confirm that I was correct.
The 14 hours starts when you first go on duty, and doesn't stop until 8 hours or more is logged in the sleeper berth, or OFF DUTY. This was the major change from the "old rules" (not to be confused with the "old, old rules").
Bekins. Just sayin'. :wink:
glasman2 02-21-2007 04:30 PM
Yup.... I was just thinking after I read the topic "oh god ... here goes another one"
