What Type Of Fuel Additive Are You Guys Using?
http://www.fppf.com/images/products/fuelpowernew.jpg
I use Fuel Power additive, that I buy by the gallon from a truck supply store in Orlando for a little over $50, which is a lot cheaper than buying 8 oz. bottles at truck stops. I've used FP on a variety of cars and pickup trucks, since I got my very 1st diesel in 1984, an Isuzu pickup. My original Volvo truck w/ Volvo engine had 538,000 miles on it when I got it 5+ years ago, and I've used Fuel Power since then up to the 1,066,000 miles when I traded it in, and NEVER needed any work on injector pump or fuel injectors during all those miles. :clap: |
The only thing I ever added to my fuel tank was more fuel when it got low and a small amount of methyl alcohol when it got colder the -25.
When I serviced my truck, I would fill the fuel filters with ATF (automatic transmission fluid) as a cleaner for the injectors. I had to stop doing that when they started looking for red dye in the fuel to signify the use of untaxed, off road fuel. I was told you can purchase un-dyed ATF but I never pursued it. |
I don't use any unless it gets down to zero and I'm leaveing the truck for a few days (no place to plug it in) Never had a problem
I don't use additives. I think that most of them are a waste of money. I may use a little alcohol in my fuel if I get some water in my fuel. I have also been known to add some transmission fluid. That is all that I use. I have only been checked one time for dye in the tank. I still had the container for the transmission fluid. It wasn't a problem.
A fuel sample would resolve any questions about the content of your fuel tank.
When its done at the side of the road there is NO analysis, it is the officers discretion, you should know how that will work, and the fine is usually by the gallon based on full fuel capacity, because they will assume that the tanks were completely full of the dyed fuel at one time or another. Try to fight it in court see whose favor it comes out for. Remember how most states are cash strapped. As far as additives I don't use any, maybe only if its gonna be real cold. Heres a link to an oil additive test you might find interesting though What about Additives? |
We are talking about fuel, rather than oil additives. But as far as oil additives goes, I add Lucas Synthetic @ 20%.
I have never been a supporter or user of additives of any kind. I never put anything in my crankcase but conventional motor oil. I never put anything in my differentials or transmissions but conventional gear oil. I never put anything in my radiator but green antifreeze. I never put anything in my tires except air. A lot of people told me I was just being stubborn but their equipment wasn't lasting any longer then mine. I guess this helps me understand why. I wish I could say I was that smart but the truth is, I couldn't see spending extra money on something that didn't have a clear return on the investment. Even in my cars I do the same. Valvoline 5w-30 in both the wife's PT Cruiser (197,000 mile) and my Dakota (142,000). I also put cooler thermostats in both of them right after we bought them. I have always thought that the 195 degree t-stats were too hot to get serious miles out of a gas engine. They both run at 180 degrees. I'm guess I'm just and old school, old fart. |
I use Lucas in my fuel everyother fill-up (so twice a month)
Always add Lucas every oil change. I'm a little over a million miles on my 74 Pete's rebuilt BIG 3 and still doesn't burn (or leak) a drop...... injectors/pump are the same, never been changed. |
3 or 4 times a year they do it in the town i live in. they just stop EVERY car truck or semi going thrught town |
BTW: In the five years I've been an O/O, and a combined total of maybe a year on the road before that since 1991, I've NEVER had my fuel tested. Not even once. :thumbsup: |
I have only been checked 1 time and that was in Montana back in '02 |
Iuse lucas fuel treatment every 10,000 miles when I sevice my truck. fill the primary filter with it & the rest goes in the tanks. always saw a m.p.g. increase when using.
It's my understanding that there are bacteria that can (and, I guess, do) grow in the bio-fuel. In states like IL, MN, and IA, you can find bacteriacide for sale as a fuel additive. I've had to change my fuel filter a couple of times after fueling in IL and MN. I did try that additive a couple of times when I fueled there and the filter did last longer, so there may be something to that. With company trucks, you simply call the shop and ask then where they want you to have the filter changed.
Fuel goes in the fuel tank. Oil goes in the oil fill. Transmission fluid goes in the transmission. Brake fluid goes in the brake reservoir. Anyone who is putting transmission fluid in their fuel is a fool, and I challenge them to prove it does anything positive at all. "I haven't had to change injectors in blah blah number of miles" is not proof.
LOL. |
I had some guys swear to me about the Lucas oil additive lately. So I asked my mechanic about it. I don't put anything in anything without asking for his opinion. He pretty much said it's bunk. Everything in Lucas is already in the oil you put in, providing you're using a good oil . I just stick to regular oil changes.
Asinine statements like: Quote:
I just realized something. I've been drinking Dr. Pepper for the past 20+ years. I haven't needed any work on my heart during all those years. Therefore Dr. Pepper must be the reason.:clap: :roll: |
If all these additives work so well why don't the manufacturers require their use? Less warranty repairs and longer life.
Not only that, but if they worked there would be a big fleet endorsing the product, after all a fleet of 10,000 or more trucks could benefit from some of the claims of the snake oil, I mean additive |
if you ever have your fuel gel up, you will believe in anti gel additive.
My drivers use additives when the temps get to O and below. Just don't add things all year long.
I don't consider anti gel to be the same as this other garbage that people throw in their fuel. |
When I was young, way back when the earth was still cooling, I used to add ATF to the crankcase of gas engines to quiet ticking hydraulic lifters. It worked very well because of the added detergents. It helped clean the sludge and varnish from inside the engine better then anything I have ever seen. I'm not saying you need to believe it, I'm just telling what I did and why and offering what I experienced for results. I'm not offering any empirical evidence here that there was a positive result but there was definitely not a negative result. Other then ATF, I'm like you. Oil in the crankcase and fuel in the fuel tank and air in the tires. |
If you use a quality oil in the first place there would be no need for an additive to clean. Used to add solvent to car motors before tearing down to make clean-up easier.
Saying that detergents in ATF keep the fluid clean implies that there is dirt that the detergents are taking away. If so, then where is this dirt going? Does it just magically disappear? Furthermore, why not throw a bottle of laundry detergent into your fuel tank. After all, if it's detergents you're looking for, then any old detergent should work, right? But doing something like that would just be crazy. |
Furthermore, why not throw a bottle of laundry detergent into your fuel tank. After all, if it's detergents you're looking for, then any old detergent should work, right? But doing something like that would just be crazy.[/QUOTE]
Thanks alot,now i need to siphon all the fuel out of the trucks. |
Don't do that man, just ride the Tide. Get it. :lol: |
The detergents don't keep the fluid clean any more then laundry detergent keeps the water clean. They keep the dirt from building on the inside of the transmission. The filter traps the dirt, keeping the fluid clean. In the case of ATF in fuel, the contamination is microscopic in the injectors and when released by the detergents they go through the combustion chamber of the engine and get burned. The newer low sulfur fuels are much cleaner so the need to use ATF or any other cleaner probably doesn't exist anymore. Whats crazy is assuming that all detergents are the same. Are all lubricants the same? Would you put grease in your crankcase or oil on your 5th wheel. Some detergents would be considered acid and some would be considered base. Many of the detergents used in products made from crude oil are themselves made from the same crude oil. Not even remotely something you would want to wash your cloths with. A lot of laundry detergents today are organic meaning their made from base compounds and plants. If it says green on the bottle, it's probably organic. Your an interesting person Rev. You seem to have a very cut and dried, short sited view of things. If everyone thought that way, we would never have put a man on the moon and we would probably be driving ox carts instead of a trucks. |
One would think if it actually did what you're claiming, the ATF manufacturers would be repackaging their product as injector cleaner and selling it at an inflated price. |
