I run a Cobra 29 LTD ST, power upgrade to 45-50w, M-84 Mic, and have no complaints. The upgrade cost me 65.00, the mic was another 60.00, and i got the radio for free to begin with, so....
I can put out almost 20 miles sending on a clear late night on flat land....now if only i could hear that far away. No retarded roger beep, echo, or any of that really annoying crap that is evident of someone having too much time on their hands, and spending too much time on their cb. |
and i got the radio for free to begin with, so.... I can put out almost 20 miles sending on a clear late night on flat land....now if only i could hear that far away. No retarded roger beep, echo, or any of that really annoying crap that is evident of someone having too much time on their hands, and spending too much time on their cb. |
Originally Posted by JeffTheTerrible
Your antenna has a major impact on your reception. The Wilson 2000 or 5000 are good antennas, with high dB gains, and will help improve your reception. Or a Monkey Made is an excellent antenna, although they are somewhat pricey.
There are three standards that antenna gain (loss) is judged against. (1) 1/2 wave diople. (2) 1/4 wave and (3) isotropic antenna. The isotropic antenna is an antenna that does not exist. It is a mathematical model. If you doubt what I say is true then email Wilson and ask them what the db gain is for their antenna vs a 1/4 wave antenna. No retarded roger beep, echo, or any of that really annoying crap that is evident of someone having too much time on their hands, and spending too much time on their cb.
The "home base-ers" seem to think it's madatory to have roger beeps in their radios. Echo has its uses, until some jackass gets the bright idea of turning it all the way up, then it gets quite annoying.
kc0iv |
TRAM WILDCAT MODEL WC-73
CB ANTENNA - 26 to 30 MHz - TRIPLES THE TRANSMIT AND RECEIVE - 73" OVERALL HEIGHT - 47 1/4 STAINLESS STEEL 17-7 ph TEMPERED WHIP - TRIPLE HEAVY-DUTY GIANT CHROME PLATED *BRASS COIL - 12.9 DB GAIN - TRIPLE WAVE - 15,000 WATTS Any opinions on this one? |
Originally Posted by kc0iv
Sorry to inform you but there isn't a mobile CB antenna made that has true gain. The lenghts are just to short. What Wilson is really saying is their antenna has less loss than the other brands. Any antenna that is shorter than 102" (for the CB band) has a db gain of less than one (-db).
There are three standards that antenna gain (loss) is judged against. (1) 1/2 wave diople. (2) 1/4 wave and (3) isotropic antenna. The isotropic antenna is an antenna that does not exist. It is a mathematical model. If you doubt what I say is true then email Wilson and ask them what the db gain is for their antenna vs a 1/4 wave antenna. Anyhow, for the purpose of keeping it simple, I said "gain", instead of going into a diatribe which would have caused unecessary typing, but, it looks like I failed to avoid that either way. Anyhow, since we're at it, know anyone in the market for some Swan radios, in excellent condition? 6m, 10m, and 15m are available. I just simply don't have the time anymore. |
I've been messing with these things for a while, being a licensed amateur radio operator for some time (with a "KF" call; not some newbie with "KG" or "KH", or whatever is being assigned now Now with all the banter back and forth about antennas and what is good... None are, all mobile antennas are compromises plain and simple. All the huge coils and rhetoric spouted about Wilson and the others is just that, rhetoric. Unless a driver can install a true 1/4 wave antenna cut for 11 meters, the antenna is worthless.... Let's see 1/4 wave antenna cut for 27Mhz... 10 feet 4 inches. Not including radials!!!! |
all mobile antennas are compromises plain and simple. |
Originally Posted by Doctor Who
I've been messing with these things for a while, being a licensed amateur radio operator for some time (with a "KF" call; not some newbie with "KG" or "KH", or whatever is being assigned now Now with all the banter back and forth about antennas and what is good... None are, all mobile antennas are compromises plain and simple. All the huge coils and rhetoric spouted about Wilson and the others is just that, rhetoric. Unless a driver can install a true 1/4 wave antenna cut for 11 meters, the antenna is worthless.... Let's see 1/4 wave antenna cut for 27Mhz... 10 feet 4 inches. Not including radials!!!! And to say the antenna is worthless.. well, that's a statement which leaves room for debate. Perhaps in comparison to a base antenna, it would seem so. But, there are mobile antennas of varying quality available. |
You should know the region - 4. Don't bother though. I haven't transmitted, even for net checks, in almost two years. I won't give out the full call for the same reason I wouldn't give my address or phone number out online. Let's see 1/4 wave antenna cut for 27Mhz... 10 feet 4 inches. Not including radials!!!! |
The reason I asked about your call is the fact that I may know you I've been licensed for 17 years and probably was the guy who issued you the test...
Anyhow, forgive me if I appeared to be rude with my statement. It wasn't my intent. |
| All times are GMT -12. The time now is 08:33 PM. |
