Stomper Electronics at the TA off exit 63 on I85 in South Carolina is the ONLY shop that'll ever touch a radio of mine again. Check him out if you're ever in the area.
If you're not real big on using the CB, and don't care to play in DX Land, that Cobra, coupled with a Francis or Firestick antenna, should do you quite nicely. |
CB RAIDOS
SO HOW DO GET GOOD RECEPTION ON A T2000 KW JUST SHORT OF RUNNING A NEW ANT
Re: CB RAIDOS
Myself, I might have to get one because the truck Ill be driving is a T600 with the plastic mirrors. Any suggestions folks? |
Re: CB RAIDOS
Rob.
The T-600 antenna mounting location is on the mirror arm, and grounding should not be a big issue. If it is an issue you should be able to run a metal strap from the antenna bracket to a bolt on the door frame. Grounding becomes an issue on truck like Volvos and Centurys where the stock mounting location in on the mirror itself. |
Originally Posted by Uturn2001
Rob.
The T-600 antenna mounting location is on the mirror arm, and grounding should not be a big issue. |
you can skin a little spot on the coax and solder a wire to the braided wire then tape it up , then it then hook it to the ground post right there in the cab
Another thing... for those of you with metal mirrors:
1: make sure your mirror mounts are tightly bolted, or you'll lose your ground. This will eventually burn your radio out. 2: if you have paint on your mirrors, scrape it off where you're mounting your antenna, or else you won't get a ground to begin with. 3: Get your SWR tuned on your antenna, or you'll end up burning out your CB. If you do not wish to do this, or don't know how, then you're best off to buy a Francis antenna, which are individually tuned to run with an 18 ft coax. |
Well having used "Big Radios" and small I have found the uniden PC 76 to be an outstanding choice for the average user. the new cobras are just trouble in a box..With soundtracker that is I had a galaxy 99 for years and it was a great radio and a Ranger 2970 but the truth is if you dont use the sidebands or ham bands why pay for em?
Also I second the opinion that with a good antennae and co-ax you can make an inexpensive radio sound great.. Spend your money on a wilson 2000 and you will never be sorry. also a single ant will always work better than duals. the trick is stay away from the rip off cb shops..Johnsons corners in colorado is an honest fair shop. they can actually repair radios. |
| All times are GMT -12. The time now is 11:52 AM. |
