Justruckin |
03-29-2010 10:58 AM |
Originally Posted by arky
(Post 477731)
DieselBoss, I'm guessing this won't work, but want to ask anyway. Would the vuqube work if mounted on the 'inside' of a fiberglass sleeper such as a F'Liner Condo ? Would any of the other systems work for this setup?
I can answer that one, no, it will not work. You need to mount it on the outside as high up as possible to clear the trailer and any tractor obstructions. I had mine mounted on the back of my Volvo 780, with about 2 inches of the top of the VuQube showing above the roof line. It worked like a champ.
One thing though, if you do get one of the units, I would caulk around the seam where the top and bottom of the unit go together, as dirt tends to get into the interior of qube and eventually gums it up. I caulked all the way around and left a 1 inch break at the back, facing trailer, to allow for expansion/breathing. I had one of the very first units, before they went national and King Dome bought them. The King Dome units seem a little better built, as I have owned both.
Was it worth it? Yes, I would not truck again without one.
Mike
