Another GPS Question (Sort of)
OK all you electronic experts out there I have a question.
I run MS S&T on my Toshiba "Satellite" laptop......the factory speaker just ain't cutting it. Even with the volume on high, it is very difficult to hear the spoken directions with road noise, etc. So, I plugged in a pair of ordinary Walkman type speakers into the jack that is normally used for headphones......volume on high and still can barely hear the spoken directions from the GPS. ALL other programs/applications come through loud and clear (in fact too loud on high). I even bought a pair of so called "laptop speakers", the ones that plug into the USB port. Again, same issue as before. ALL other programs/applications are loud and clear but the GPS is not. Any ideas on how to correct this.....if it is even possible?????? |
I bought a $20 set of amplified speakers from Target and it works out great for me. You don't need anything great, just something with some true amplification. If you've got an inverter in the truck, find a set that plugs into the power, or get a small inverter (cig lighter style) to power them.
Streets & Trips is bad on the volume level of the spoken directions however. You might check on www.gpspassion.com and do a search there. I think I've seen it mentioned on how to overcome the problem with it. |
1. In Control Panel, open Sounds and Audio Devices.
2. Click the Audio tab. 3. Under Sound playback, click Volume. 4. Move the volume and wave sliders to the top. |
Re: Another GPS Question (Sort of)
Plug it into the speaker jack on the computer, and TURN THE COMPUTER VOLUME DOWN (if you don't, the sound is all distorted). Then just set you FM radio to the correct station, and your computer will come through the truck's stereo. :wink: |
I'm gonna have to head over to Wally world and see if I can get one of them there gadgets :) is there a particular name brand to look for? |
BTW....with that device using the radio, that means I have to sacrifice listening to the radio then?
It is similar to this one: http://www.walmart.com/catalog/produ...uct_id=4694330 |
You never did mention which version of Streets & Trips you are running, or did I miss it? Anyway, when I ran the 2006 version, it was barely audible. However, when I switched to the 2007 version, it was loud and clear, with out an FM modulator or amplified speakers. Even with the satellite radio on. Microsoft beefed up their text to speech engine in the 2007 version and the volume, at least on my computer, comes in loud and clear.
