-   -   Dump Valves (https://www.classadrivers.com/forum/truck-maintenance/39302-dump-valves.html)
RostyC 01-01-2010 12:07 PM
Dump Valves
The dump valve on the rear axle of my spread axle flat recently "took a dump" on me. It was a Peter/Paul valve. I couldn't find a Peter/Paul to replace it with so I put on a Haldex. I'm not satisfied with it at all, it's way too slow to exhaust the rear bags.
I would like to find something even faster than the Peter/Paul valve, if possible. What brand of dump valves are you guys using? Where can I get one?
Thanks guys.
smith1979 01-02-2010 12:53 AM
Oil Cooler on a 60 series detroit
I am having trouble getting the oil cooler off of a freightliner my boss just bought it and it has been sitting up north for an while and the oil cooler is eatten up with rust and I can not get it off to save me I have pulled the turbo and everything out of the way and took the bolts out but cant get it to turn loose can any one give me any ideas
GMAN 01-02-2010 02:28 AM
Thanks guys.
The last dump valve that I bought came from Truckpro. I don't recall the name, but it dumps and refills very quickly. Truckpro or Fleetpride should have them. I have found my local people are very knowledgeable about the products they sell. You could also check with some of the trailer dealers to see what they recommend.
RostyC 01-02-2010 02:41 AM
yeah GMAN I've called some places and asked about the Peter/Paul and only one trailer place was familiar with the brand. The other guys were lost. I did find a couple on ebay last night, one P/Paul and the other was a Hendrickson, I believe.
Thanks for the reply.
Bigmon 01-02-2010 04:59 AM
He probably thought you were talking about a music band or candy bar.:)
RostyC 01-24-2010 12:26 AM
Figured out my problem yesterday. Apparently Haldex marked the valve as a "open valve" when in fact it is a "closed valve." I'm going to take the valve back to Baltimore Freightliner and see if they'll exchange it but I'm not too optimistic. We'll see.
