-   -   Filter Wrench (https://www.classadrivers.com/forum/truck-maintenance/37631-filter-wrench.html)
Fredog 04-12-2009 09:10 AM
Originally Posted by Orangetxguy (Post 446345)
I got one of those style wrenches for free last monday evening. Had my oil changed at the Petro in Shreveport. Found their wrench on the oil filter during an enroute check, the next morning. Also saw that they didn't change the filter!
:o:o:o No...I did not stand there and watch them change the filter. I figured I shouldn't have to! Since I had the service done on monday night, tuesday morning I checked the oil, but I did not shine my flash light onto the filter! :o:o
Got a new oil change when I got to the Petro in West Memphis AR that evening.
:angryblue::angryblue: The bad thing about finding that filter wrench....I also found coolant coming from the "weep hole" on my water pump. I ended up dropping my load at our Memphis terminal and getting the water pump replaced. 3 days for the right pump to show up....freaking Cat's!! :angryblue::angryblue:
try speedco next time,when they are done, they take you to the truck and show you everything that was done.
Larry227 04-14-2009 03:37 PM
Try not to tear it up too bad. I'm pretty sure there's a core charge on those dessicants. Could depend on where you buy them though.
jonp 04-14-2009 10:47 PM
Originally Posted by Fredog (Post 446310)
napa has one that has a very heavy leather like strap and and 1/2" square fitting so you can use a 1/2" drive ratchet on it, I havent met a filter yet that it cant take off. you could probably get it at a truck dealer also
it looks like this http://i42.tinypic.com/3499sb4.jpg it's 22.50 at mytoolstore.com
I've got one like that and have used it for years. Pretty bullet proof and fits about everything. I think that I got mine in a wal-mart. Mine has a fabric strap to it and is a little frayed now but I swear by it. I've actually crushed an oil filter with it using a cheater bar.
magna19 04-19-2009 03:29 AM
if i remember correctly a cat filter wrench fits them nicely.be carefull trying to spin them off since the body is aluminum,and the cartridges sometimes do not come off easy at all,if they havent been changed recently.i have spun quie a few off and boogered the threads on the housing,then its change the whole dryer off.
