[quote="flood"]well check the oil level, check the water level. if it's to low that will kill it.
That won't kill it 2-3 secs after it has started |
Originally Posted by pdm
There should be a wire directly from the batteries to the ecm & also might have a fuse in the battery box. make sure the wiring is ok. If its bad it won't run, but i don't think that the engine lights on the dash will power up either.......
There is 5 wires to the ecm, 3 ground and 2 live. |
Originally Posted by Collard Greens
flood how dry out the moisture? oh5 you mean the fault codes, if so I says no fault codes.
How are you sure there's no codes? |
| All times are GMT -12. The time now is 03:26 PM. |
