speedometer problems
just recently my speedo was spiking and then it stopped working...
my trip meter and mileage had also stopped working also.... what could be problem??? |
Re: speedometer problems
yes i was kind of leaning toward that....
i heard it was behind the tranny where the drive shaft connects.. but what does it look like???? |
It threads in AND has a locknut, and a plug with the wires, you can change it out in 15 minutes.
Just ask the parts guy how many turns to back it out after it bottoms out, I can't remember, BUT I think its one turn. Last time I changed mine it was around $30. |
quote="Maniac"]It threads in AND has a locknut,
it has a jam nut, as i stated above. locknuts have distorted threads or nylon rings that stop a fastener from backing off completely after becoming loose and a plug with the wires, you can change it out in 15 minutes. Just ask the parts guy how many turns to back it out after it bottoms out, I can't remember, BUT I think its one turn. Last time I changed mine it was around $30.[/quote] bottom it out, then back off a 1/2 turn |
cool thanks guys, i just found where the sensor is...
will be digging it out tomorrow.... yeah peterbilt quoted me $43 for the sensor... |
are there usually 2 (or more) speed sensors?
is this speed sensor the same as the one used for other sub systems? |
quote="possum squat"]are there usually 2 (or more) speed sensors?
no... ...depending is this speed sensor the same as the one used for other sub systems?[/quote] it's a magnetic pulse generator..., if that's what you mean. abs sensors as well as some engine speed sensors are the same type of sensor |
well finally pulled it out...
the tip had some fresh oil on it... i only drove it for like a half mile than i parked.... speedo works... couldn't really go far because of the weather.... hope that oil on tip isn't an issue????? |
| All times are GMT -12. The time now is 07:21 AM. |
