C16 & C15 Caterpillar
Do these engines share the same engine block ? I'm guessing they do.
And besides displacement, what are the differences ? |
I think they stop making the C-16 but dont hold me to that.
According to Caterpillar's website the C16 has not been available since 2003. The C16 had a displacement of 15.8 liters whereas the early C15 displaced 14.6 liters. There are now two versions of the C15, a 435 to 550 horsepower version and a 600 to 625 horsepower version. Both displace 15.2 liters.
http://ohe.cat.com/cda/files/209038/7/leht4565-04.pdf http://ohe.cat.com/cda/files/364480/7/LEHT4811-00.pdf |
I was curious about the 1999 thru 2003 versions of these engines.
With the bigger displacement of the C16, I'm also curious what were it's HP capabilities. With the C15 good for 550 it seems that the bigger engine would be good for quite a bit more than 600 HP. Probably the the drive train and sanity have alot to do with the numbers. |
With the bigger displacement of the C16, I'm also curious what were it's HP capabilities. ummm, capabilities as an otr engine? 625hp, probably about 800-1000hp in a marine application With the C15 good for 550 it seems that the bigger engine would be good for quite a bit more than 600 HP. 500 cid, top-fuel big blocks can make up and over 7,000Hp... that's only an 8 liter engine............ yes, there are many variables ;0) breaking that 2,000 lbs torque barrier required a larger displacement for some manufacturers. ddc also had to stroke the series 60 to get over 500 hp. Probably the the drive train and sanity have alot to do with the numbers. |
| All times are GMT -12. The time now is 02:49 AM. |
