Originally Posted by rank
You should have a much easier time than I did installing mine on a two-thirty-something wheelbase, sixty something bunk with exhaust behind the bunk.
Why do you think I insisted on getting side exhaust?
Where do you get stainless ones? I've been making my own from the corners of farmers gates.....it amounts to 1" square tube bent 90 degrees. Works good. Don't forget to isolate the steel from the aluminum with rubber.
Kenworth part #K275-6001SS
SS fairing bracket LF4
$44.00 each
They even gave me the small screws for the fairings, but not the bolts that go into the sleeper. I'm having a real bitch of a time removing those.
Today(thursday the 2nd):
- Finished oil change
- Finished DRL install and put together dash
- Two front shocks
- Adjusted steering box (required partial removal)
- Dicked around with steering stops, only to realize it's the steering box that sets the limits. It doesn't even come close to the limiters on the axle!
- Removed lower two fairing brackets (with some damage)
- Finished p/s filter/oil change
- Did one rear brake chamber
- Both front brake chambers, needs two new slacks (they were different brands anyways)
Discovered:
- Passenger side step has no provisions for storage
- The truck only has 3 batteries
