Originally Posted by YerDaddy
Not if you're behind me!
I bought the smoke tarp when I bought my three piece 8 foot drop tarp set. I just don't want to have to use it anymore than I have to.
Isn’t it a safety violation to have even the electrical line dangling on the catwalk like that?
I’m torn with what to do about the lines. I finished the project of relocating my muffle and removing the one fuel tank a couple days ago and got the rack mounted (temporarily) to the rails. My welder / fab / CNC guy just ordered the diamond plate to make my full fenders and catwalk today so I need to figure out what I’m doing with the lines ASAP because we’ll be doing the fenders and catwalk no later than Friday (I hope).
I have several ideas in mind. Right now I have the troublesome stock coiled lines (removed from the truck right now) with the old “springy dick” suspension for them. I’m thinking about keeping the aluminum angle that all the lines mounted to the frame though and placing it 12 to 18” beneath the front of the rack. Then I could bolt one of the shorter grab rails I cut off the back of the cab, to the top face of the rack, and attach one of those long springs that are commonly used with straight lines to the rail with a carabiner that would allow the spring to freely slide, but also allow me to quickly disconnect it if it’s in my way. This method would be best if I went to the straight lines, because when I dropped them from the cabiner, they’d fall flat to the catwalk and be less of a tripping hazard.
The second solution is to mount the slider rail underneath the rack (either directly to the bottom of the box or to the top of the legs) and then attach the clamps that hold the lines together to the rail with the carabiner. The only advantage to this method is that it would keep the lines below the doors of my cabinet and negate the requirement of having to drill holes in and cause possible leaks in the top of my box. Tomorrow I’ll probably have to make poopy or get off the pot and do something.
If anybody wants to see pics of anything I’ve done so far just let me know and I’ll post what I’ve done so far.
