Originally Posted by sjmay
Hey Rank,
That is very helpful as well, I am assuming that Canadian/American doesn't matter, if you are in Canada, you have to follow their HOS rules, along with FMSCA rules etc, they are very similar though so...
If you were to drive in Canada, assuming that Canadian regulations mirror American regulations....You would be very wrong indeed, and could find yourself talking with MDOT and writing them Comcheks to pay your fines.
The first and most important aspect of crossing into Canada,is having done a 36 hour reset, before heading to Canada. A 34 hour reset here in the States does not count up there...only the 24 hour period that you had while doing the American reset, counts for anything. Canadian HOS regulations give you 2 extra hours driving each day......and 3 hours of extra "time". HOS regulations are different for each region of Canada as well. The "Southern Tier" provinces (Canada Main) have one set of regulations, while the "Northern Tier" provinces and the "Maritime" provinces (Canada North) are on a different set.
Canada has a longer set of "total hours worked" (285?), before a full reset is necessary, but Canada requires a 24 hour off duty period once each 7 day period. As an American, MDOT will look at you harder than they will a Canadian driver....simply because of the "Cowboy Mentality" associated with the "American Trucker". If your truck is equipped with Qualcomm or Peoplenet, you are less likely to get a full inspection than a driver running a comic book.
When in Canada, follow MDOT regulations. When in the States, follow the FMCSA regulations....never try and work under both. Just make certain you are legal before you cross the border, which ever direction you are going.
