Originally Posted by firebird_1252
if i knock it down to a 435 do you think i can knock 6.5mpg or better?
No. It will probably get worse. It is an Acert, and if you could run it steady at 1300-1350 rpm, ON A FLAT GROUND, you should get 7.0-7.5 mpg, or better. Running 70-75 at those specs, would do you 6.0 at best, but i wouldn't bet on it. If you want a CAT, to run at those speeds, look for 3.25 or higher. That's wont be a problem on a flat ground. Make sure your torque is 1850, than you might get 6.5 mpg, if slowing down, is not an option....
