Originally Posted by jd112488
so i was following this swift truck across the scales here in the buckeye on I70, out by cambridge. he rolled across and got the green light, but he went around back and got in line again. he rolled over the scales again and again got the green light. this guy turned again and was going to go over the scale again. the scale master finally got on the radio and said,"swift what the hell are you doing, i gave you the green light two times?" the swift driver said,"well, i am out of hours and them other drivers said if i was out of hours, to just go around the scalehouse!!"
You need to put up a disclaimer that this is a fictional story if using Swift as the driver ,because it could a true story ...What tipped me off was the Swift driver understood /spoke English easily .
