http://www.irs.gov/publications/p463/ch01.html#d0e820
Special rate for transportation workers. You can use a special standard meal allowance if you work in the transportation industry. You are in the transportation industry if your work:
Directly involves moving people or goods by airplane, barge, bus, ship, train, or truck, and
Regularly requires you to travel away from home and, during any single trip, usually involves travel to areas eligible for different standard meal allowance rates.
If this applies to you, you can claim a standard meal allowance of $52 a day ($58 for travel outside the continental United States) from January 1, 2007, through December 31, 2007.
Using the special rate for transportation workers eliminates the need for you to determine the standard meal allowance for every area where you stop for sleep or rest. If you choose to use the special rate for any trip, you must use the special rate (and not use the regular standard meal allowance rates) for all trips you take that year.
Travel for days you depart and return. For both the day you depart for and the day you return from a business trip, you must prorate the standard meal allowance (figure a reduced amount for each day). You can do so by one of two methods.
Method 1: You can claim ¾ of the standard meal allowance.
Method 2: You can prorate using any method that you consistently apply and that is in accordance with reasonable business practice.
http://www.irs.gov/publications/p463/ch06.html#d0e7803
Hours of service limits. If you are subject to the Department of Transportation's “hours of service” limits (as explained earlier under Individuals subject to “hours of service” limits in chapter 2), use 75% instead of 50% for meals while away from your tax home.
