I'm not a trucker so go easy on me if this is a dumb question. I have 89 Freighliner COE and someone broke my driverside CAB tilt release handle. I assume they were trying to get at the batteries since they also stole my running lights and gas caps. Since I don't know how they broke the handle I have little knowledge of what is wrong.
I manufactured a new handle (to replace the broken one) but now there is zero movement in the cam (lever) mounted to the cab and zero movement of the dual springs. The rod going from the handle to the cam just flexes.
The Passenger side has a chrome safety pull lever and the painted release handle moves smoothly. When the cam (lever) rotates the dual springs move away from the frame bracket. There is no such movement on the stuck drivers side.
The truck is new to me an in order to get the plates (vin verification) and my license (pre-trip) I must be able to tilt the cab.
Does anyone have an idea why the release mechanism is stuck? Is this a common problem on the COE? Is there perhaps too much tension on the dual springs (they have a bolt going through them). Is there a way to disassemble and fix this?
Additionally; is it just me or do the COE have extremly sloppy shift linkage? Any aftermarket fixes to make the shifting better?
Thanks for any and all tips.
