Originally Posted by ripp_jr
can a person have 2 different dot numbers i have 2 different companys a towing and over the road trucks need a diff for the towing company for insurance when i applied it said my social was already on file its two diff buisness need help
If you operate under two separate business entities, then you will likely need 2 dot numbers. If you operate under a single name and authority, then you should be able to use the same number.
