Originally Posted by tracer
Originally Posted by GMAN
I always tell a shipper or broker that it will cost them extra for tarping. When you add services, you need to expect to pay more. I find it interesting when I tell them about the extra tarp charge that it can sometimes suddenly NOT really need to be tarped. :roll: On the other hand, there are legitimate reasons why some loads need to be tarped. I have known owner operators who refuse to take any load that needs to be tarped. If you don't want to deal with the tarping, then I suggest you check into pulling vans or buy a flat with a curtain-side, Conestoga or similar tarping system. Those will add about $17,000 to the price of your trailer. You can haul almost anything with a Conestoga. You may also want to check into side kits. They run from about $1,800-3,600. The lightweight kits are more expensive than the plywood kits. You will usually need to break down part of one side to load and unload. A side kit is more versatile than other types of tarping systems. And then there is also the difference in purchase price.
But with side kits you can only take low loads like steel, aluminum logs, or coils. you'll have to say 'no' to lumber and most construction materials, right?
You are not limited at all with a side kit as long as you are willing to break it down and stow it on or under the trailer. I usually stow mine on the front of the trailer. There are companies that make storage compartments that fit underneath the trailer. If you are unwilling to break the kit down, you will limit yourself to some degree with lumber, etc. To me it isn't a great sacrifice since wood products are usually cheap. I rarely haul lumber. In fact, I am not sure that I have hauled a load of lumber in more than a year. With a side kit you can still haul over width loads as long as you break down the kit.
Each trailer has it's benefits and drawbacks. Flats and steps cost more than most vans, and then there is the cost of tarps and securement equipment. Any type of open trailer will require some physical effort. Each load is somewhat different. If you don't want to tarp I would suggest not getting into open trailers. You may be happier with a van or reefer. All you usually do with either is drive. There are some exceptions where you will need to assist in unloading, however you can choose to hire a lumper to do that work for you.
