Originally Posted by GMAN
There are trailers specifically designed to haul boats. Depending on the height, a flat could work, but most likely it would require a step deck. With that length you will need a 53' step because of the length. I have a 42' bottom deck on my 53' step deck. I usually get at least $3/mile for my step deck doing over sized, plus permits. Boat haulers can charge $4/mile or more, but have most of the special blocking you need to safely haul boats. You may find someone who will do it for less. If the boat is more than 8'6" then it will not work on most flat beds. My step deck will legally haul anything up to 10' tall. If it is more than 10' tall then you will need either a low boy or boat trailer to move the boat. Most states will not allow more than 13'6" tall, some of the Western states will allow you up to 14' tall. Of course, you can usually permit for higher loads.
If you go with a carrier you need to check their motor carrier authority and insurance. If you have their motor carrier number it is easy to go to the federal website to check the status. You can have their insurance company send you a certificate of insurance. There are companies who specialize in hauling boats, but I can't think of any of them right now.
Perhaps a double drop with outriggers. Would sure lower it down more. I'll tell you what, I will do it for $1,000,000 or I can do it for $250,000 and you buy the fuel.
