Originally Posted by jdfrc
literally, on the back of your docking station for sirius is a small hole. put a small sheetmetal screw in there it may be 1/8" if that much. screw it down eliminates the vibration and holds the two units together Should eliminate the static.If that doesn't do it call tech support ,they will have you send it in to be repaired or replaced no cost to you. Been there done that drove me nuts I even bought a new stereo for the truck.
just go to tssradio.com and order an f/m modulater, its about 20 bucks, you plug it into the back of your radio and plug your regular antenna into it and then the modulater plugs into your satellite reciever, when the satellite is off your f/m works just like normal, when the satellite is on you get no static at all, I had to put one on my sons car because the fm stations around here are so strong and it works perfectly.
