I believe that it means that the company can not make you take a load you are free to refuse. This however does not mean that your company won't make you life harder if you refuse to take a load. That is the definition that I know of. Hope it helps.
Thanks for the reply...that was my take on what it means also. When hubby tried to refuse a load, his company informed him that 'no forced dispatch' meant that 'the company couldn't force him to run over his HOS'. As far as I know...DOT has the say in that rule
If I had employees, I'd be damned if I let them refuse loads. If they want to do that, then they ought to start making the truck payments, the insurance payments, etc.
Most company jobs (I'm sure there is a minority exception out there, but I have yet to see it) are forced dispatch. Many O/O jobs are as well.
The company your husband works for has forced dispatch. As far as "'the company couldn't force him to run over his HOS'", they can't force you to run illegal, forced dispatch or not. They would be violating the law.
Sounds to me like Dispatch just put the screws to the driver...creating their own definition of "Forced Dispatch" to get a load off their board. Kinda makes you say...hmmmmmmmm
Sounds to me like that could be construed as false advertisement. but then again maybe not.
Even companies who say no forced dispatch have ways of making you take a load. send u a load and you refuse they say thats all we have take it or set for a few days then u have no choice. Or they could just put you to the bottom of their load list which could make you set for a couple days as well. :cry:
Forced and non forced dispatch has different meaning at companies.
At most companies forced dispatch means you take the load(s) given you.
Non forced dispatch means you can choose to take the load or decline it.
Sadly some companies and/or dispatchers think that forced dispatch means you take the load that is assigned as it is assigned and to hell with the rules and regulations.
There are 12,00 more trucks then drivers, and if someone doesn't want to take a load, then let the company find a driver :?
