Originally Posted by armadillo
I know you can with all your knowledge...
JUST -by LOOKING at the pattern (pictured) of the eaton 13 speed, it doesnt look as if you GET 13 spds, please explain so my girly friend can sleep at night. thanks a
You do have 13 forward gears on the 13 speed!
On the low side, you have a 5 speed pattern, where 1st is low gear.
When you split to high you are using a 4 speed pattern and don't use the low gear position again.
So you have 1 - 5 on the low side.
4 gears in direct.
4 gears in overdrive.
For a grand total of 13 forward gears!
