I?ll try this again.
I wasnt all over both lanes, but with a load 10' high and 35' long it doesnt take much to sway a truck with 20 mph winds.
Are you using a 1 ton dually pick-up?
Some ? ton duallys are rated at 11,000 pounds.
Ford Fleet Highlights
Commercial E-News
February 8, 2006
'At 10,000 lb' GVWR Offerings on F-350 SRW Pickups and E-350 DRW Cutaway (138" Wheel Base) and Stripped Chassis (All WB's)
The 'at 10,000 lb' GVWR is a significant option because of the Federal Motor Carrier Safety Regulations (FMCSR). This option has been provided due to individual States & Municipalities increasingly adopting the 'interstate commerce' regulations for 'intrastate' operations and the impact of these regulations on trucks with GVWR's at or above 10,001 lbs. The FMCSR impose additional driver (i.e. driver hours of operation) and vehicle (inspection, repair, maintenance) logging requirements, insurance minimums, and other requirements that can be very costly for Fleets to implement. An 'at 10,000 lb' GVWR truck is not subject to the FMCSR regulations. For a greater understanding of FMCSR requirements visit the National Truck Equipments Association's website.
SRW = Single Rear Wheel
DRW = Dual Rear Wheel
The E-350 is a van, the F-350 is a pick-up.
Ford Commercial Site
My truck is listed at 10k and trailer at 16k.
The CDL is driven by the
MANUFACTURER?S GVWR not the registered weight.
Commercial motor vehicle (CMV) means a motor vehicle or combination of motor vehicles used in commerce to transport passengers or property if the motor vehicle-
(a) Has a gross combination weight rating of 11,794 kilograms or more (26,001 pounds or more) inclusive of a towed unit(s) with a gross vehicle weight rating of more than 4,536 kilograms (10,000 pounds); or
(b) Has a gross vehicle weight rating of 11,794 or more kilograms (26,001 pounds or more); or
(c) Is designed to transport 16 or more passengers, including the driver; or
(d) Is of any size and is used in the transportation of hazardous materials as defined in this section.
Gross combination weight rating (GCWR) means the value specified by the manufacturer as the loaded weight of a combination (articulated) vehicle. In the absence of a value specified by the manufacturer, GCWR will be determined by adding the GVWR of the power unit and the total weight of the towed unit and any load thereon.
Gross vehicle weight rating (GVWR) means the value specified by the manufacturer as the loaded weight of a single vehicle.
So if your pick-up is rated at 10,001 pounds or more, your trailer 16,000 then you must have a Class A CDL.
And yes since you need all my personal info sealord, I carry commercial insurance for the exact items I haul for 750k liability, and Motor Carrier enforement stated that most of the scrap haulers are cutting corners, therfor I will be looked upon.
The $750K could be a problem:
Thats what Im hoping. Iadmit Im a young-un-26 years old, but im financing this whole thing on my own, and have started from scratch hauling junk cars. I have been told you will be looked upon the same as a trash hauler. But I do try to run safe and legal.
?387.9 Financial responsibility, minimum levels.
The minimum levels of financial responsibility referred to in ?387.7 of this subpart are hereby prescribed as follows:
SCHEDULE OF LIMITS
(Public liability)
(3) For?hire and Private (In interstate or foreign commerce: in any quantity; or in intrastate commerce, in bulk only; with a gross vehicle weight rating of 10,001 or more pounds)
Oil listed in 49 CFR 172.101; hazardous waste, hazardous materials and hazardous substances defined in 49 CFR 171.8 and listed in 49 CFR 172.101, but not mentioned in (2) above or (4) below
$1,000,000
Cars (automobiles are a Class 9 hazardous material listed in the hazardous materials regulations, i.e. 49 CFR Part 172.101:
Automobile, motorcycle, tractor, other self-propelled vehicle, engine, or other mechanical apparatus, see Vehicles or Battery etc.
Vehicle, flammable gas powered, 9, UN3166
Vehicle, flammable liquid powered, 9, UN3166
There are exceptions for some Class 9 material from placards and shipping papers when in domestic transportation. However, since automobiles are listed in the HMT, the $1,000,000 of insurance is required.
http://hazmat.dot.gov
www.fmcsa.dot.gov
Be safe.
