You can just flag your pretrip, not using any minutes, then you can do your inspection anytime later. I always combined it with loading or unloading, 15 min. only.# 2 - No, one 15 min. inspection in 24 hrs. is all that's required. I have been doted many times and all I show is a 15 min inspection whether it's during loading, unloading, or during fuel, one line drawn down for 15 min , and that's it. Everything else I just flag, and have never had a ticket on my logs. Wasting 15 minutes for fueling, loading, unloading is something the personal companies require, but the only thing in the reg's is one 15 min. inspection in a 24 hr. period.
Cases have been built for 70 hour rule violations using 15 minutes for pre-trip/post-trip inspections, 15 minutes for fuel each fuel stop and 15 minutes for loading/unloading when drivers fail to log such events and the driving time indicated the 70-hour rule was close. Roadside officers do not do the in-depth investigation the DOT does during compliance reviews. When a CR is performed all documentation is used to investigate, i.e. driver trip sheets, payroll, fuel receipts, bills of lading, repairs, roadside inspections, etc. The DOT reviews a minimum of 30 days for the drivers selected for HOS.You can just flag your pretrip, not using any minutes, then you can do your inspection anytime later. I always combined it with loading or unloading, 15 min. only.# 2 - No, one 15 min. inspection in 24 hrs. is all that's required. I have been doted many times and all I show is a 15 min inspection whether it's during loading, unloading, or during fuel, one line drawn down for 15 min , and that's it. Everything else I just flag, and have never had a ticket on my logs. Wasting 15 minutes for fueling, loading, unloading is something the personal companies require, but the only thing in the reg's is one 15 min. inspection in a 24 hr. period.
Rev.Vassago:
No - this section of FMCSA code pertains to Pre Trip inspections - not in-route inspections. It must be done prior to driving. There are no regulations for in-route inspections, except for certain operations (such as hazmat, oversize, etc.)
Incorrect, Part 392 states:No - this section of FMCSA code pertains to Pre Trip inspections - not in-route inspections. It must be done prior to driving. There are no regulations for in-route inspections, except for certain operations (such as hazmat, oversize, etc.)
?392.7 Equipment, inspection and use.
No commercial motor vehicle shall be driven unless the driver is satisfied that the following parts and accessories are in good working order, nor shall any driver fail to use or make use of such parts and accessories when and as needed:
Service brakes, including trailer brake connections.
Parking (hand) brake.
Steering mechanism.
Lighting devices and reflectors.
Tires.
Horn.
Windshield wiper or wipers.
Rear-vision mirror or mirrors.
Coupling devices.
I have always considered this the in-transit inspection. Every time the driver exits the vehicle then these items should be checked before the driver continues operation. Drivers are often asked when was the last time they checked the vehicle when safety defects are discovered.?392.7 Equipment, inspection and use.
Steering mechanism.
Tires.
Horn.
Coupling devices.
Be safe.
