I will have to talk to my trainer about that. I was under the understanding that if you work 14 hours, you can drive 11, but you can sleep 2 periods equaling 10 hours in the sleeper berth. Originally Posted by MeDNag
Actually, having two breaks in the sleeper that total 10 hours does not equal 10 CONSECUTIVE hours as DOT regs call for. As I was told, DON'T even try this unless you have to. It's easy to screw up and not worth the time lost out of service if caught or the money for the fine.
Here is what I got from safetruck.org:
Technical Amendments Clarify Sleeper Berth Regulations
The Federal Motor Carrier Safety Administration (FMCSA) has issued technical amendments clarifying the new hours-of-service regulations. The majority of the revisions deal with clarifying the sleeper berth provisions.
Under the new rule, effective January 4, 2004, off-duty time is included in the calculation of the 14 consecutive hour on-duty limit. The only exception allowed to this provision is when a driver uses the split sleeper berth to accumulate 10 hours of rest. When taken in 2 periods, each of which are at least 2 hours (totaling at least 10 hours),
the sleeper berth time does not count towards the 14-hour limit. This means that the following must be counted toward the 14-hour limit:
* on-duty time;
* off-duty time not spent in the sleeper berth;
* sleeper berth time of less than 2 hours; and
* sleeper berth time of 2 hours or more that is not one of the 2 periods used to accumulate 10 hours of off-duty time.
A combination of consecutive sleeper berth time and off-duty time totaling at least 10 hours may be used to comply with the 10 hour off-duty requirement in sleeper berth operations.
