Originally Posted by Papa Rick
I could not find in the letter if I am to do a inspection sheet on both my:
Pre-Trip Inspection and Post-Trip Inspection.
The letter states that the Pre-Trip should take 5 minutes, just a quick walk around to check: Tires, etc......, and the reason for the 5 minutes is that at the end of the previous day, it should have taken 30 minutes to 1 hour to do the post-trip, which is very detailed.
I don't have to keep a log book due to the fact that I stay within 100 air mile radius so I don't have to log it, but just want to be sure to be legal.
Any suggestions and advice would be greatly appreciated.
The paperwork sheet gets done on the post trip inspection.
Good luck doing a pre trip inspection in 5 minutes. :lol:
Here's what a pre-trip consists of:
§383.113 Required skills.
(c) Air brake skills. Except as provided in §383.95, all applicants shall demonstrate the following skills with respect to inspection and operation of air brakes:
(c)(1) Pre-trip inspection skills. Applicants shall demonstrate the skills necessary to conduct a pre-trip inspection which includes the ability to:
(c)(1)(i) Locate and verbally identify air brake operating controls and monitoring devices;
(c)(1)(ii) Determine the motor vehicle's brake system condition for proper adjustments and that air system connections between motor vehicles have been properly made and secured;
(c)(1)(iii) Inspect the low pressure warning device(s) to ensure that they will activate in emergency situations;
(c)(1)(iv) Ascertain, with the engine running, that the system maintains an adequate supply of compressed air;
(c)(1)(v) Determine that required minimum air pressure build up time is within acceptable limits and that required alarms and emergency devices automatically deactivate at the proper pressure level; and
(c)(1)(vi) Operationally check the brake system for proper performance.
§392.7 Equipment, inspection and use.
No commercial motor vehicle shall be driven unless the driver is satisfied that the following parts and accessories are in good working order, nor shall any driver fail to use or make use of such parts and accessories when and as needed:
Service brakes, including trailer brake connections.
Parking (hand) brake.
Steering mechanism.
Lighting devices and reflectors.
Tires.
Horn.
Windshield wiper or wipers.
Rear-vision mirror or mirrors.
Coupling devices.
Here's what a post-trip consists of, besides the paperwork:
§396.11 Driver vehicle inspection report(s).
(a) Report required. Every motor carrier shall require its drivers to report, and every driver shall prepare a report in writing at the completion of each day's work on each vehicle operated and the report shall cover at least the following parts and accessories:
Service brakes including trailer brake connections
Steering mechanism
Tires
Horn
Windshield wipers
Rear vision mirrors
Coupling devices
Wheels and rims
Emergency equipment
