4.No power inverters allowed in trucks
Actually, I agree with this one on Heartland's side. It's a safety issue, through and through. We've had several trucks over the last decade burn to the ground because of an improperly wired inverter. We had a truck here a few months back that was smoking from front to back from some of the most eye-popping wiring you've ever seen. The truck was a deathtrap and luckily someone called it in and tragedy was averted. But one of these days, a driver is going to die when his truck goes up and that's not something we want to see happen.
What about the shop installing it, since I know that will be the next question. Same thing applies...what happens if a shop employee installs it wrong and the driver dies when the truck goes up? Again, not something we want to see happen
I don't understand this one myself much either ...The wiring for an inverter is Simple ... And the only way to have a huge fire easily is to use to small of a gauge wire for the install...Now as for the shop installing a simple inverter wrong ,and it being a potential danger to the driver ,and equipment...If the shop can't install something as simple as an inverter how can they service the rest of the truck safely without there being a daner to the driver . :wink:
Qual-coms are also not factory from the manufacturer of the trucks ,and therefore they must be wired into the trucks electrical system ...It's the shop that usually install the qual-coms ...could not a fire result from bad electrical connections from installing a QUAL-COM ? :wink:
