logging no no?
I now run the same route 5 nights a week and am home from about 0200-1500 hrs.
this is where the question comes in. I am logging this time on line 1 off duty. An other driver said thats wrong(I know I shouldn't listen but now worry about it) he said it should be logged on line 2 or I need a hotel reciept for DOT. I start logging and end at the same time and same location so it's evident that I must be home. |
Line 1 - Off Duty
If you're at home why would you need a hotel receipt? There is nothing that says your off duty time has to be spent in a hotel.
Re: logging no no?
Re: logging no no?
Re: logging no no?
OH-MAN, I'm in trouble now :shock: I've got blue sheets! What about the blanket? :lol:
thanks for the info, I kina figuered off duty is off. I'm sure it would be different if I was still OTR |
While you logging "gurus" are "on duty" (not driving) I hope!,,,,, :D
I have a quick question. What is the maximum number of hours allowed for driving during a 24 hour period? I know it sounds like a basic premise of HOS, but I just recently realized it isn't. |
13.75 the 10 hour break resets the clock for you and you have your next 11 to use. Under the old 10 and 8 there were plenty of days I did 15.75 as long as I had that 8 hours in between shifts DOT boys said I was fine. Trouble is you will fry your hours faster than Rosy Odonnell gets fired from the View.
you can be on duty for 14 hours out if which you can drive for 11 hours, then you must have 10 hours rest, so the maximum time you could drive during a 24 hour period would be 11 hours It would be no more than 13.5 hours in most situations. (Figuring 2 vehicle inspections during that time). |
Now what exactly is trucker math? :lol:
I have a quick question. What is the maximum number of hours allowed for driving during a 24 hour period? I know it sounds like a basic premise of HOS, but I just recently realized it isn't. 11 am until 9 pm sleeper berth = 10 hours 9 pm until midnight driving = 3 hours Theoretically, 14 hours, but that isn't going to happen in the real world. |
without having to load or unload, you will have to pre tip.
That is going to cost one half hour, depending on your tank size, you might have to fuel, there goes half hour more. The only way to get out of that one, Is to fuel and pt at the same time. the way it is you can not steel from the ten off, but you can from the three on duty. twenty is more like it. The rev forgot to pre trip twice so his 14 is in all reality going to be 13 |
That is going to cost one half hour, depending on your tank size, you might have to fuel, there goes half hour more. The rev forgot to pre trip twice so his 14 is in all reality going to be 13 11:45pm - 12:00 am = pre trip, tanks are full 12:00 am - 11:00 am = 11 hours driving 11:00 am - 9:00 pm = 10 hours sleeper berth 9:00 pm - 9:15 pm = pre trip 9:15 pm - 12:00 am = 2 hours, 45 minutes driving Total driving time: 13 hours, 45 minutes. The real question should be: Why would anyone want to drive 13 hours, 45 minutes in a single day? |
In theory, you could have done a pre-trip at 11:45 pm, and started driving at 12:00 am. That eliminates one pre-trip right there.
so now your day is twenty four and a quarter long. You're assuming fueling is necessary. never had a truck run without yet. Didn't forget anything. I purposely left them out. But in the interest of fairness, here's a best case scenario for a single day. nice one. try telling that to the scale master. seventy two point pre trip in 15 Min's that's refreshing :roll: |
I was thinking 24 hr period,,, that is any 24 hour period, does not have to begin or end with the date change.
So 13.5 hours, drive 6.75 off 10, drive 6.75, but I guess 13 would be closer to reality with fueling. And as one said you would use up your total hours rapidly and probably wear your ass out quickly. |
not yet[/quote]
Learn to quote, please. Also, learn what "best case scenario" and "theory" mean. So the next time I get called into a scale, I will tell the scale master that this is my best case scenario, in theory. |
Originally Posted by Fredog
ok, there are 24 hours in 24 period so the maximum number of hours you could drive in a 24 period would be 24.. I didnt say maximum allowed, I said maximum possible. Okay, Rev, let's see you dispute that
ok, question here.
I do a 15 min fuel/pre-trip drive for the day then do a "quick" post-trip. I log 15 minutes in the morning, but since i do a quick one at night, i only flag it (ie 7 minutes or less) legal? my understanding is if it's 7 minutes or less you can flag, over 7 minutes you need to log to the nearest 15 minutes / 1/2 hr. when i started driving, everything i did was eating up my hrs, then someone told me about flagging and saved me a ton of time ( when needed ) |
Originally Posted by glasman2
ok, question here.
Correct. Anything less than 15 minutes can be flagged.
Re: logging no no?
Re: logging no no?
this is where the question comes in. I am logging this time on line 1 off duty. An other driver said thats wrong(I know I shouldn't listen but now worry about it) he said it should be logged on line 2 or I need a hotel reciept for DOT. I start logging and end at the same time and same location so it's evident that I must be home. While its best to have a copy of a motel bill to substantiate a stay in a motel, its not 100% necessary. I stay in motels that the company has contracts with....I just sign in and sign out. I do not necessarily get a copy of the bill. If I show more than 10 consecutive hours off duty the point is "moot". I have met the requirements according to the "Fed". http://www.fmcsa.dot.gov/rules-regul...ochure2005.htm The answer to a possible rebuttal: In the event a DOT officer wants proof that I stayed in a motel....I would hit the auto-dial on my cell phone calling the terminal that pays that motels bill...and have them validate the log entry to the nice officer. Push come to shove...if the officer insists on seeing the motel bill...a call to the motel with the DOT's fax number would take care of that. But, funny thing is....I have NEVER been asked for the motel bill... Oh, if for some reason I stay in a motel due to "breakdown" away from a terminal....and I pay the bill and send it in for re-imbursement... I do keep a copy of the bill with me....as much to compare to my pay statement as anything else. Trucker math: A method of computing numbers that arrives at the desired results with absolutely no correlation to reality" :mrgreen: :mrgreen: |
Re: logging no no?
Pre-trip is only required once every 24 hours.
Mark |
Mark |
There you go again pre trip is in your day. 1 If you change trailers 2. at anytime you stop for more then 10 hours or any change of service.. :twisted:
kc0iv |
kc0iv §396.13 Driver inspection. Before driving a motor vehicle, the driver shall: (a) Be satisfied that the motor vehicle is in safe operating condition; (b) Review the last driver vehicle inspection report; and (c) Sign the report, only if defects or deficiencies were noted by the driver who prepared the report, to acknowledge that the driver has reviewed it and that there is a certification that the required repairs have been performed. The signature requirement does not apply to listed defects on a towed unit which is no longer part of the vehicle combination. §396.11 Driver Vehicle Inspection Report(s) Question 2: Does §396.11 require that the power unit and the trailer be inspected? Guidance: Yes. A driver must be satisfied that both the power unit and the trailer are in safe operating condition before operating the combination. Question 3: May more than one power unit be included on the DVIR if two or more power units were used by a driver during one day's work? Guidance: No. A separate DVIR must be prepared for each power unit operated during the day's work. |
kc0iv §396.13 Driver inspection. Before driving a motor vehicle, the driver shall: (a) Be satisfied that the motor vehicle is in safe operating condition; (b) Review the last driver vehicle inspection report; and (c) Sign the report, only if defects or deficiencies were noted by the driver who prepared the report, to acknowledge that the driver has reviewed it and that there is a certification that the required repairs have been performed. The signature requirement does not apply to listed defects on a towed unit which is no longer part of the vehicle combination. §396.11 Driver Vehicle Inspection Report(s) Question 2: Does §396.11 require that the power unit and the trailer be inspected? Guidance: Yes. A driver must be satisfied that both the power unit and the trailer are in safe operating condition before operating the combination. Question 3: May more than one power unit be included on the DVIR if two or more power units were used by a driver during one day's work? Guidance: No. A separate DVIR must be prepared for each power unit operated during the day's work. Needless to say I know those rules. However, I want to see the part that says "2. at anytime you stop for more then 10 hours or any change of service.." kc0iv |
| All times are GMT -12. The time now is 06:09 PM. |
