-   -   disabling a qualcom for..a few minutes...is it possible? (https://www.classadrivers.com/forum/rules-regulations-dac-oh-my/29982-disabling-qualcom-few-minutes-possible.html)
kc0iv 10-06-2007 07:57 AM
Originally Posted by countryhorseman
I would have to look itno it, but as of the first of this year, Werner was the only one authorized by the FMCSA to be completely paperless.
Curious if some are doing the electronic logs, but have to print it out and have a signature. Would be interesting to know. I know TMC was testing a system for paperless, but the drivers still had to back it up with a paper log.
Thanks
You might want to look at: http://fleetowner.com/information_te...ard_recorders/
kc0iv
Double R 10-06-2007 08:08 AM
Since there is only one company in the nation authorized to use paperless logs at this time, it is not hard to figure out who you work for. That company will terminate you immediately for tampering with the QC, ECM or any other electronics in the truck.
Best advice, DON'T do it!
Before long, many of the larger companies will be going paperless within the next year or so! So we might as well get use to it.
I know of, and have driven for some, several companies that use paperless logs. Werner may be the only mega-carrier doing it but they are certainly not the only carrier doing it.
Thanks
Alot of the local companies around have a "paperless log" system. Not the same as what Werner has though. It records the drivers time but like you said, it needs printed and signed.
Anyway, what is a Qualcom? I have never had one in my truck before. :lol:
yes I know what a qualcom is, just never used one
Fredog 10-06-2007 08:10 AM
Originally Posted by jedfxg
i thought if you hung it out the passenger side window that it went away?
that doesnt work, but saltwater does.
Double R 10-06-2007 08:15 AM
Do qualcoms make good wheel chocks? I think some should try it and let other drivers know.
Drew10 10-07-2007 01:24 AM
Where did Zen Road Warrior go??? Its been 7days since he "kicked off" this post. I wonder if he tried disabling his qcomm, or hiding his "signal" from the Werner police, and now he is long gone.
Deus 10-07-2007 01:54 AM
We have paperless. I work for a smaller carrier and no logs need to be signed.
I don't know if there are any differences between Werner's system and others on an administrative level; but there are none on a driver level.
Scoe 10-07-2007 05:14 AM
I have driven for carriers that have done the same, paperless and no need to sign it with an actual signature.
CJH1977 10-24-2007 06:07 AM
There is a carrier here in Maine that has completely paperless logs. no need to print or sign anything. Almost identical to Werners system.
mike3fan 10-24-2007 01:17 PM
Walmart is switching over to paperless also,my Dad runs it and he doesn't have to print or sign anything.
Outta here 10-27-2007 11:08 AM
We're testing something through a phone set-up through Nextel. Has the log on the screen. Lots of bugs in it right now.
Got to 50 posts
