Another reefer question. (Need load advice)
Just booked a load says it has to be between 36-46*. How would you guys approach it? I'm thinking 39* on cycle? Advice please.
It's been awhile since I ran reefer, but I remember cycle would maintain your temp between a 10 degree margin… so if you set 39 on cycle, it could go 34-44
I think I would set 41 degrees continuous. things to consider of course, outside temp- day time or night time transport- how long to deliver… hours? days? full or partial load, new or old reefer :) |
When I ran reefer, I remember setting all my produce loads on continuous, and only my frozen loads on cycle. :)
Product like you are talking about can be maintained best on a continuous temperature setting. On frozen loads, you can use your cycle setting, because the frozen product can handle a 5 degree variation in the core temp, without damaging the product. |
Depends on what the product it.
Solid dense mass type stuff can handle cycle better. Leafy type things and other produce are really sensitive to temps swings and need continuous. You can really tweek this knowing the settings on your reefer. It would also depend it its summer or winter. Like the last couple, I'd run on the lower end of the range, dead of winter, on the higher end. Ice cream I run continuous. Cheese I run cycle. Melons and onions conituous because the piss so much moisture. |
It's pharmaceuticals.
Originally Posted by firebird_1252
(Post 531487)
As a side note. I've been offered one pharmaceutical load. I turned it down because I didn't have insurance to cover the load had something happened. Just an observation. |
Yeah this is only 3 pallets. Papers say between 36-46*
I'd suggest looking at getting a bulkhead for loads like that. Easier to control the temps.
With so little in the box, I'd run 38 continuous. Cooling a ton of space is a big temp swing with no product. |
Problem is the return load is to the tail so no room
For the bulkhead. I got it set to continue |
I slide mine on top then flat
| All times are GMT -12. The time now is 05:23 AM. |
