-   -   Another reefer question. (Need load advice) (https://www.classadrivers.com/forum/owner-operators-forums/44840-another-reefer-question-need-load-advice.html)
firebird_1252 07-25-2014 03:00 PM
Hmm. That's not a bad idea! Especially the reefer we are using is old. Where is the best place to put it? Right after the shoot?
mndriver 07-25-2014 03:04 PM
Fitted correctly, it blocks off the chute as it's really a false wall and the front of it is all you are cooling. I just ran an ice cream load and it was nice. 2P4D and after my second drop, had less than 1/2 the trailer to cool. It's nice too when you back in with a load and doors open to put the bulkhead up to prevent sucking in all the moisture as well and constantly cycling for defrost.
I'll normally put a load lock up high even with the last pallet, slide the bulkhead in place and the put a load lock about in the middle holding the wall in place. Never had it come down yet.
