Smoke Tarps and a Dirt Burner
If I have a "dirt burner" (horizontal, under cab mounted exhaust), and the load information says it requires a smoke tarp, do I still need to use the tarp? I mean with a dirt burner there's no smoke to damage the load.
I think I would be inclined to put the tarp on anyway- when I hauled siding, we had to use salt tarps in the winter- but winter was determined by the calendar, not by the weather or road conditions. If we didn't have the tarp on, we didn't get paid for the load. Thankfully, I never found that out the hard way, but I know of drivers who did.
Originally Posted by Musicman
(Post 505361)
I believe I would check with the shipper, or even better, the receiver, and see if they require that you put a smoke tarp on. If they tell you "YES", I would follow orders. Otherwise, when in doubt, TARP THE LOAD. I've done that and it saved my butt more than once. For that matter, it doesn't take much to put a small tarp on the front of the load. Not like having to tarp the whole load. I always carried a "half-tarp" just for that. |
(Post 505376)
For that matter, it doesn't take much to put a small tarp on the front of the load. Not like having to tarp the whole load. I always carried a "half-tarp" just for that. I’ve never driven a truck with a dirt burner either, but I’m about to. I decided to remove my vertical 5” rear mounted exhaust and put it under the truck so that I could move my headache rack further forward on the rails. I also removed a fuel tank, which I have been debating doing for over two years. Removing the passenger side tank made the exhaust project a lot simpler and it will save about 1,100 pounds to boot. Moving the exhaust underneath the truck saved close to 100 pounds between the brackets and pipe I was able to get rid of. |
(Post 505381)
My pipes are on the side, next to the tanks, shipper said no smoke tarp needed, this is an old pic, sold the flat in 2008
http://img.photobucket.com/albums/v2...cotrip2020.jpg |
Originally Posted by rank
(Post 505420)
That's funny, I did the same thing a week ago so I could install a headache rack. Only, I didn't want to go the grass burner route so I ran a 5" pipe up the back of the bunk and bolted it to the headache rack so the headache rack is now doing double duty as a exhaust stack support.
http://tlwoods.com/images/05semicab6.JPG Because it's a fairly deep cabinet, I thought moving it all the way forward would be the thing to do to give me more room to route the air and electrical lines and also open my options a little regarding where I can set my fifth wheel. |
Originally Posted by Maniac
(Post 505421)
My pipes are on the side, next to the tanks, shipper said no smoke tarp needed...
I would appreciate any suggestions regarding a cost effective solution to my fender problem. Below is a pic from the website I ordered my rack from. Check out this one solution for fenders and let me know what you think.
http://tlwoods.com/images/05semicab3big.JPG Also, I’d love to see pics or hear suggestions of what to do with my electrical and air lines. Right now I’ve settled on mounting the grab rail from the back of my sleeper onto the bottom front of my headache rack and attaching hanger hardware and a short spring from there. Right now I have the coiled type lines, by the way. |
(Post 505422)
Doing that wouldn’t have accomplished anything in my situation, as the 10” muffler would’ve still been behind the sleeper causing the headache rack to be mounted no closer than fourteen or more inches from the back of the cab.
(Post 505422)
The rack I bought is the three door cabinet type, 67”H x 84”W x 14” deep, like the one below, except I ordered mine with polished diamond plate:
As for the air lines, so far I have coil spring attached to the top of the headache rack with an s hook. The spring hangs down and supports the lines. |
| All times are GMT -12. The time now is 05:40 AM. |
