2006 387 MPG Results
Ok, so I figured I would start a thread with my different MPG numbers for the new truck.
I run a dedicated lane, 4,500lbs down and empty back in a J&L Dry Bulk tank for roughly 2,700 miles round trip. My route never changes and it goes as follows: Westville, IN (US421 to I-94 to I-57) to Tuscola, IL. Then from there I take I-57 to I-55, I-40, I-30 to Texarkana then AR549 to US71, I-220, I-20 to US79 to US59 thru Houston to Victoria then TX185 to Seadrift. On my 1st trip this week I set my cruise at 1,350rpm which put me at 67mph. I got fuel and avg 7.2mpg for the trip down. On the way back, i set my cruise at 1,250rpm which was 62mph and I avg 7.85mpg. Next week i am going to set it at the 1,250rpm down loaded and see if it makes a difference with the 4,500lbs in the tank, which i doubt it will, but ya never know. |
Since you run the same route with the same freight, I'd do a week at each RPM, then use the average for that week as the MPG for that RPM. Even though minor, things such as the wind, temperature and humidity will affect the MPG's. Just an idea, anyway.
Originally Posted by Malaki86
(Post 494812)
So, what's the point? What are you trying to find out? With that kind of weight, you don't need to worry about pulling power. You want better MPG, you run between 1250-1300 RPM. In your case it's 62-64 mph. You want to drive "faster", you'll have to pay for it. That simple. Have fun tho...
in new zealand you could tow that weight behind a 4+4 ute and get 10ks to the litre,just a thought
Originally Posted by solo379
(Post 494827)
Originally Posted by Steel Horse Cowboy
(Post 494849)
What can I say, i get bored
Not to mention i did plan on doing some mods such as Pittsburgh mufflers, and maybe a PDI ECM and figured with my run being the same, I could post some REAL WORLD numbers up as I go along.
(Post 494863)
(Post 494868)
Just for fun, ask any Pete dealer, how much is your muffler. I was thinking about the same thing, or Walker Noise-breakers, but it might be illegal emission wise.
I know my truck is not CARB compliant, so it keeps me out of CA anyways, but that's fine with me as I don't like going there. The Pitt mufflers are $275 for my truck a piece... but their same muffler that is 10" shorter, but the same width is $189? Since I'm going to replace the top of the stacks anyways, I think I'll go with the shorter muffler and a longer top stack (tyes it will fit, I measured) so the tops will be basically free! And the are 50 states legal!!!!!!!!!!!!!! "Our new performance muffler solution for the 387 This muffler uses a acoustic louver sound dampening This muffler is noticeably louder than our Quiet Performance muffler Up to 50 additional horsepower and improved response Lower exhaust gas temperatures Fast return on investment and easy fuel mileage gains Extra heavy duty construction. " |
(Post 494902)
Why not just buy the donaldson 1000463 for $70.00 from ryder fleet products online? same as the p.p, one. straight thru design without the loud noise. http://www.ryderfleetproducts.com/ry...oductDetail.do
(Post 494935)
Why not just buy the donaldson 1000463 for $70.00 from ryder fleet products online? same as the p.p, one. straight thru design without the loud noise. Ryder
(Post 494927)
They are legal noise wise, but i was talking about emissions. CAT ACERT suppose to have catalytic converters in it. I was quoted $2500 each(i've got 2) at KW dealer.
S.H.C. I am like you on the m.p.g. I document the mileage at every stop & every fill up. I know the wind, hills, weight, e.t.c. have a lot to do with the different m.p.g we get, but I want to keep track to see too what is the optimum speed,rpm to get the best m.p.g. without lugging the engine or going ridiculously slow. I also keep tabs on my m.p.g. to help me determine if anything may be needed such as time for overhead run or cac leaking. these can affect m.p.g. I had a great tailwind pushing me down i-65 last week. got 7.0 mp.g. had to recalculate 3 times to make sure I added the numbers correct. some may think different on this, but I have always put 5 lbs more air in tires than posted on sidewall. all mine show 105 psi. I put in 110 psi. none of them stay at 110 in the cold weather, they all drop over time. keep on experimenting with your m.p.g. & any other truck related info. it will be of use to someone.
(Post 494957)
this is my 2nd ACERT CAT enigne and none of them had catalytic converters on them.
(Post 494956)
Because the DOnaldson one is only 9" wide, and mine are 11" wide.
(Post 494966)
That's why i've said ask your dealer. My truck is 2005, actually maid in may 2004, and engine february 2004. If it has no converters, why is such price? I'm trying to figer this thing out, let me know what did you find out....
(Post 494849)
I just was seeing what the benifits were to driving slower compared to faster....or in this case, if things keep up this way, it will cost me $100 a week to go 4mph faster. Just was shocked at the idea was all. What can I say, i get bored doing the same damn thing each week LOL
Originally Posted by repete
(Post 494975)
Are you sure it will ONLY cost $100 a week? That seems a little low to me after all thats only 25 gal. I'm just wondering. You get bored doing the same thing every WEEK? I do the same 3 roads every NIGHT! I watch the pot holes age!
(Post 494972)
aparently most KW's that have the stack out the rear (like mine) such as a T600 or T2000 doesn't have mufflers,
http://i6.photobucket.com/albums/y21.../DSC000252.jpg |
Yeah, I have the one under the bunk, then 2 in the back. One on each stack :c
What year is your truck? Maybe one is a regeneration system seeing the only trucks I know that have 2 under the cab are 07+ emissions motors. Is that it? |
What engine/transmission/rear-end combo are you running in that truck? I'm somewhat surprised that you're getting better mileage at 62 than at 65. For me, it was the opposite... then again, that was a computerized governor, not the sole of my right boot doing the governing.
Originally Posted by VPIDarkAngel
(Post 495344)
well, this last week was a bust. I had STRONG headwinds for about 200+ miles of my trip to Texas. I wound up getting 6.75mpg going down set at 62mph.
My trip back home was the same headwind for 200+miles, then nothing. I fueled in MO and was at 7.25mpg set at 65mph. Looks like this is going to take some time, but I will admit, at 65mph (1325rpm) the engine seems to run smoother and pulls hills much easier. The truck is currently at peterbilt having the shift-tower busings replaced (stick is sloppy as could be) and having the overhead ran since I'm sure it has prob never been done, and at 517k miles, I figured it was a good time for it. I'll update next weekend if it has improved at all. I also am looking at going straights on the rear, and leaving the factory resionator/muffler underneath and seeing how that does, then might measure it up and see if I can get a high-flow replacement for it on down the road :smokin: |
great thread, lots of good methodology and business thinking in here. Better than $30 an hour paid to you for 3 extra hours on the road...
Originally Posted by LBF
(Post 495374)
Personally, if I had pipes behind the sleeper I'd go to single straight. Less weight and less wind drag.
Originally Posted by YerDaddy
(Post 495424)
This week was a bit different. I set my cruise at 65mph (1,325rpm) for the entire trip. The wind was calm and not much stop-n-go this week. I avg'd 7.25 loaded and empty both ways. The truck ran smoother, I was able to stay ahead of most company trucks (JB, SNI, Werner, US EX) and made average time.
I think this is where I'm going to run the truck at for the next few months and start doing my upgrades...... first will be a 3 axle alignment to see if it makes a difference (plus who knows if it has ever been done) then I'm going to get the new mufflers, then have the overhead ran. After that, I'm going to try a few other things such as a ECM tune and a few online things I have read for the C13. |
The good rule of a tumb;-If it's not broken, don't fix it! Of course i didn't mean scheduled maintenance intervals....
(Post 495660)
I'm very particular, where i do alignment, and overhead. And definitely wouldn't mess with ECM unless i have to....
(Post 495689)
Just an update....I have been averaging 7.25mpg with the truck and am not very happy. I honestly thought it would do better since I run empty everywhere I go, and I keep it under 65mph.
That being said, today I did a mod I heard about with the fuel wire, and also my boost wire going to the ECM. The truck deff idles much smoother, and the throttle response is great. I don't think i will gain any MPG yet, but I will check it out on this weeks run. Next weekend I am removing the resionator/convertor and putting in a piece of straight pipe, thus eliminating one issue. I have been told that I should gain about .3mpg with that, then going to replace the mufflers on the back with some Donaldson high flows and see how she does. If i can even gain .5mpg total I will be very happy!!! |
(Post 496263)
That being said, today I did a mod I heard about with the fuel wire, and also my boost wire going to the ECM. The truck deff idles much smoother, and the throttle response is great. I don't think i will gain any MPG yet, but I will check it out on this weeks run. Next weekend I am removing the resionator/convertor and putting in a piece of straight pipe, thus eliminating one issue. I have been told that I should gain about .3mpg with that, then going to replace the mufflers on the back with some Donaldson high flows and see how she does. If i can even gain .5mpg total I will be very happy!!! Also notice most big fleets didn't use Cats,even when they were available, there is a reason and fuel mileage is the biggest one. |
Originally Posted by Maniac
(Post 496274)
You are getting about all you will ever see with a Cat, just how it is, the Cats are NOT fuel mileage engines,never were, just ask anybody that has one.
Originally Posted by rank
(Post 496277)
True.....but I've never pulled 4500 lbs with it either so I wouldn't know. OMG that is light. Seems like overkill to me. I bet my little M11 would get 9 mpg on that run.
As for being light, I love it till winter comes around. Then it is a nightmare to deal with. Heck, even on a dry day I lock up the trailer tandems just rolling at 25mph and stopping. Scares the carp out of the 4 wheelers if I have to brake quick on the interstate. All that smoke tends to make them go for the median LOL |
(Post 496274)
You are getting about all you will ever see with a Cat, just how it is, the Cats are NOT fuel mileage engines,never were, just ask anybody that has one,
Also notice most big fleets didn't use Cats,even when they were available, there is a reason and fuel mileage is the biggest one. I'm just kicking myself in the ass for getting rid of my old trusty FLD. I should have just spent the $2000 on the clutch and hit the road, but as usual, I had to make an impulse buy LOL |
| All times are GMT -12. The time now is 08:22 AM. |
