Spec'ing a TRIdem stepdeck
1 Attachment(s)
OK, no more RGN for me..
Let's hear some views on spec'ing a tridem step. Don't actually need a tridem but our Heavy Haul allows me to permit heavy loads with a tridem. So, it's good for the future and stuff over 49,000 lbs (what I can haul legally now). Wilson has a sloped gooseneck (45% angle), so that you can move tractors and such from the lower deck onto the upper deck. The option costs just over $1,000. I think it's a good thing to have. [ATTACH=CONFIG]673[/ATTACH] Here's what I picture: Total length: 53 Top deck: 10 ft Kingpin setting: 16" (all RGNs have 10ft decks and 16" kingpins, what's good for them should be good for a step) Lower deck: 43 ft Gooseneck: sloped, 45% angle (see the pic above) Composition: combo (steel plus aluminum) In-the floor tiedowns (6,500 lb rating) Double spools Stake pockets Aluminum floor with 4 nailers Steel coil package? (loads of pre-tarped steel coils from IN to ON, Canada) pay 3 bucks per mile Tridem: 72" spread between axles; this would give me the highest weight rating in ON and USA 3 m to 3.6 m - 24,000 KG 3.6 m to 3.7 m - 26,000 KG or 57,200 lbs 72" between each axle is 3.65 m for the entire tridem group, hence the 26,000 KG allowance. Wheels/tires: I have been bit**ing about my tiny tires but the reality is they DO allow to pick up some DD loads: with my 36" deck I can move stuff up to 10'6" tall, so I'd probably get a tridem with the same 17.5' tires, all aluminum wheels. D-rings: I don't have these on my current step, but I"m thinking it'd be good to have them to tie down heavy equipment, at least 3 or 4 on each side. Winches: Wilson finally has come up with a new design for the stepdeck winches and they no longer SCRATCH the side panel. Instead, they run on a rail underneath, just like in most flatbeds. Neat! PS: In Western Canada (Alberta) you get 24,000 KG maximum if the tridem is between 3 m and 3.7 m. |
Maybe you could get a rear lift axle, lift it when you don't need it to save tires and brakes and it will corner better as well, u don't need a switch in the cab, i have seen trailer that have a switch on the trailer to lift or drop the axle.
Originally Posted by bikerboy
(Post 493144)
A few thoughts:
- This trailer will be heavy. Even all aluminum would be around 11.5k-12k properly equipped - Look into lift axles - There are some that can even make you a 13" kingpin with 8 foot upper. Chaparral comes to mind (all aluminum) - At these weights you really have to mind the frame ratings. As well as clearance for your rear bumper. - Isn't this the same trailer I told you to spec out before you bought that wilson? ;) - Get Michelin XTA 2 energy tires, not XTA energy. The first have better weight ratings. The second you cannot even fully load in Canada. If you're going to go with an RGN soon, why bother buying a new trailer now? I'd recommend sticking with what you have. If not, you might be able to sell me this 53' trailer in 2 years as long as it's light enough. Here's a few: 2011 REITNOUER BIG BUBBA DROP W/35" DECK HEIGHT Drop Deck For Sale At TruckPaper.com 2012 MAC ALUMINUM 3-AXLE Drop Deck For Sale At TruckPaper.com I don't think that mac is a 2012, it's been for sale for quite a while 2006 DOONAN COMBO Tri-Axle Drop deck Drop Deck For Sale At TruckPaper.com ack, only a 48. |
Originally Posted by tracer
(Post 493145)
That sounds like a good idea but it'll probably add still more weight and cost. When I sit down with the dealer, I'll ask about this. I'm kind of tired a bit from moving my current step where the axles are stuck at the 41 ft mark. The offtrack is huge and there's nothing I can do about it, as the axles are fixed.
If you go with a 45 degree rake you can't end up with a 53 foot trailer with 10 foot top deck and 43 foot bottom.
My Doonan three axle step both the number two and three axles lifted that way it could be run short WB two axle, spread axle or three axle. The only increase in weight is the extra air bag that lifts the axle. |
A couple of short ramps will do the same thing, you need to spec a trailer that you can sell when the time comes. |
Originally Posted by Walking Eagle
(Post 493148)
Originally Posted by allan5oh
(Post 493146)
1 Attachment(s)
Here's a 94 Wilson with a sloped gooseneck and a tridem. Doesn't it look good ;) I don't know ... that sloped gooseneck makes sense to me.
[ATTACH=CONFIG]674[/ATTACH] |
(Post 493159)
I could make more money with a 53, and then get some heavy haul experience with the tridem. Trailers now - even new - are cheaper than mine, thanks to the strong Canadian dollar.
But if there's a company out there that you would benefit having a 53 foot 17.5 step, it would probably be landstar. |
dont be scared.
2011 TALBERT 2011 Talbert 55 Ton Hydraulic Detachable LowBoy Tr Lowboy For Sale At TruckPaper.com Buy that and go make the big bucks. |
1 Attachment(s)
Here's an idea that might work for me: keep the same trailer and the same monthly payments, but when I have some extra money, take my 48 ft step to a trailer body shop and get to install the 3rd axle in front of the first one in the group. Then turn the middle axle into a 'lift' axle. In this way I can run the trailer as a 121" tandem spread, or - when it's required - as heavy duty tridem. I had a steel coil package installed on the trailer at the factory, so the frame is very strong. This option might be great for those occasional ultra-heavy loads that pay so well. This investment would also increase the value of the trailer for tax purposes.
[ATTACH=CONFIG]675[/ATTACH] |
Now Tracer......I seem to recall suggesting that you get a 53 and you got a 48. I suggested you not go with the Conestoga and you wound up taking it off. I almost hesitate to do this, for fear that you will do the opposite LOL, but now I am suggesting you take Heavy Duty's advice and stay away from the sloped deck. You can get the front tractor tires up on that top deck.......we do it all the time.
I do like your idea about adding the axle though. However, I don't think I've ever heard of it being done before. |
Originally Posted by rank
(Post 493172)
(Post 493152)
May not be legal in Canada with #2 and #3 lifted especially if you have a short KP setting.
(Post 493172)
...You can get the front tractor tires up on that top deck.......we do it all the time...
4 wheel drive tractors should climb right up
(Post 493186)
(Post 493185)
Do you use portable ramps for that?
(Post 493194)
The shipper usually has ramps if they're needed. Yes, most 4 wheel drive tractors will climb up without ramps but you have s deeper drop than most so I don't know about that in your case, and yes we sometimes cobble up some sort of ramp system.....it doesn't take much. A couple of 6x6's and a plank for a ramp. Putting the load levelers at the base of the drop works too....oh yeah, I forgot you sold your levelers. You musta went through a dry box phase or something. :)
RE: Drop. Yes, that's the problem - my drop is quite big. It was difficult to get that Chevy pickup truck's front axle on the upper deck. Speaking of stepdecks vs flats, I just lost a load paying 15 (!) bucks per loaded mile from PA to ON. These were steel coils, small tarps required, 300 D/H, 250 Loaded. Weighed 47,300 lbs and it paid this much because very few flatbed guys in US could take so much weight?! That's what the Agent told me when I called. I almost got it but then she learned I had a LOW PROFILE step and that was the dealbreaker. This particular shipper had some bad experiences with low trailers in the past (they got stuck either on the railway crossing inside the plant or at the crest of the entrance door to the warehouse). So, they didn't want to load low profile stepdecks :( The sad part of the story is I can take up to 49,000 lbs LEGALLY on my step and I was ready to buy 4 small tarps at Walmart. That $15/mi rate got me all excited ;) I still can't believe all they wanted was a plain jane 48 ft flat!!! |
Believe it nor I talked with the Lead Engineer at Wilson Trailers in Iowa today! Took some effort but I finally got the answer to my trailer modification question, and Wilson said, "Yes, it can be done." The engineer said, "If you add another axle IN FRONT of the existing axle, you'll be closing the bridge, so the trailer will become stronger, not weaker." He offered to walk the Ontario trailer guys through the procedure, in case they had any questions. I just emailed this shop and asked them to give me 2 quotes: 1 for adding the third axle and the second for moving the front axle forward and creating a 121" fixed spread. It'll probably be $10K for Option 1 and around $5K for Option 2. A 121" tridem is rated in ON for 24,000 KG or 52,800 lbs. I don't want them to add deck space because that would really affect the resale value because of the seams.
My ad for the trailer is now on the Trailers Canada site and also on truckandtrailer.ca Didn't cost me a thing. The dealer is doing me a favor.
You still own the conestoga? I thought you sold that back to the dealer.
(Post 493199)
..I just lost a load paying 15 (!) bucks per loaded mile from PA to ON. These were steel coils, small tarps required, 300 D/H, 250 Loaded. Weighed 47,300 lbs and it paid this much because very few flatbed guys in US could take so much weight?!.
$3750 on 250 miles? Damn I hate coils but it's hard to argue with that. How many coils to make up that 47K? Where in PA...Pitt? |
Originally Posted by classictruckman
(Post 493242)
1 Attachment(s)
(Post 493244)
$3750 on 250 miles? Damn I hate coils but it's hard to argue with that. How many coils to make up that 47K? Where in PA...Pitt? [ATTACH=CONFIG]676[/ATTACH] |
(Post 493244)
$3750 on 250 miles? Damn I hate coils but it's hard to argue with that. How many coils to make up that 47K? Where in PA...Pitt? Here's a more or less typical example with hauling coils out of US to Canada. Origin: KY Destination: ON, Canada Weight: 45,000 Type: coils Tarp: required Loaded miles: 550 Gross rate per mie: $2.85 (including FSC). The weight is a bit on the heavy side, but I think the rate is quite good, especially when you keep ALL the money (unlike me). |
(Post 493259)
Origin: KY Destination: ON, Canada Weight: 45,000 Type: coils Tarp: required Loaded miles: 550 Gross rate per mie: $2.85 (including FSC). The weight is a bit on the heavy side, but I think the rate is quite good, especially when you keep ALL the money (unlike me). I have a 3 axle DD stretch but rarely haul heavy, the money is in big and bulky, heavy equipment don't pay enough most of the time. To much competion. How about LTL steel to Canada, should be able to put together some good loads. If you like I can PM you the best LTL agents in Il, don't know how much Canada they get but you can call and visit. |
Originally Posted by Heavy Duty
(Post 493260)
I say save the money and try chasing coils ... I have a 3 axle DD stretch but rarely haul heavy, the money is in big and bulky, heavy equipment don't pay enough most of the time. To much competition. How about LTL steel to Canada, should be able to put together some good loads. If you like I can PM you the best LTL agents in Il, don't know how much Canada they get but you can call and visit.
On the other hand, LS does have loads for tridem stepdecks! Check this listing from today:
Origin: USA Destination: Canada Dimensions: 33 ft long, 11.2" wide, 10.5" tall Weight: 59,000 lbs Gross revenue: $7,000 for 1,600 loaded miles If I had 3 axles on my 48 ft step, I could probably do it, even with a regular tractor (12K + 40K factory rating axles). That's $4.35/mi. |
I think you can still move that load. You have to permit it for width anyway, so the extra $ to permit the gross and the axles is no big deal. Usually $.30/ton*mile for the weight that needs permitting. I've done with an RGN with a closed spread so I don't see why you couldn't do it with a step.
How much weight are your trailer tires rated for? |
(Post 493289)
...How much weight are your trailer tires rated for?
You can permit 12-40-40 92000, but plan on 500-800 for permits plus some out of route miles plus you can't run in bad weather.
I know you are with LS, I was offering to give you agent numbers, 2 of the best LTL agents in the Chicago area, they have their own customers, not broker freight, both have been at it over 20 yrs. I forgot one thing, to permit for overweight in some states you need a maxium weight tag, not the 80000 tag you probably have. |
(Post 493297)
That'll be for a single trip, depending on how many states you need to run through. You can get an annual overweight for NY I think.....$400 IIRC.
I haven't hauled over 80,000 in all the states, and you didn't mention what state this 59,000 originated in, but I am plated for 80,000 in the US and I've been granted permits for 90,000 in FL, GA, SC, NC, VA, WV, MD, PA, NY. I'm thinking you're good to go in those states. As far as permit costs go, NY is the most expensive that I have run across. They are $40 + I need to use a permit service because NY won't deal with just anyone. I use Nova Permits and they charge $35. Total cost for NY is therefore $75. Toll roads require a separate permit too, BTW. NYSTA is $26 for over dimensional and their weight limit is pretty high so you may not need to permit the weight on the toll road. Watch out for MA...their overweight permits are OUTRAGEOUS once you get over a certain weight. I thought the LS agents took care of permits for the BCO's? |
Don't have time for details now but 92000 in OK $160 plus service fee, TX $210 plus, LA about $120, KS $18, IL $125, AR $150,GA $40, AL 440, OH is expensive. You can ask the agent for estimated permit charges. $560 in Ok for 132,000
If the load is inclusive permits come out of linehaul, if plus plus the customer pays actual permit charges. some states require you be plated for max weight, some will issue a permit without but it is expensive if you get checked. Some good info on LS site under info, Heavy and spec service You need to pick a permit service from the list to order your permits from, don't use Comdata. They will need truck and trailer lic number serial number, year and make and axle spacings measure from 1-2 2-3 3-4 4-5 be accurate some states measure. Most permit services charge $15-$20 to order a permit. I thought the LS agents took care of permits for the BCO's? Wrong, you are treated as an adult, you can use any approved permit service, route yourself, saves a lot of problems and misunderstandings. You also hire and fire your escorts. |
(Post 493366)
...Some good info on LS site under info, Heavy and spec service
I tried to tell you the money in flat and step is LTL. You find a piece that pays truck load that doesn't max you out then fill the trailer with LTL.
I have a piece on now that is 30' long, 15'6" wide and 13'6" tall on the ground, see what your missing. Permits,escorts, detours and weather. |
(Post 493379)
I found that section of the site, thanks. Now I don't think I want to do oversize at all :) Too many headaches. Maybe I should get a lightweight 53 step (10'1" spread) and then I can carry up to 50,000 lbs without any permits...................
If it was me, I would have as many arrows in my quiver as I could get. The more specialized you get, the more the agents will be calling you. Low trailers, long trailers, levelers, tarps, TWIC, oversize ready, cross border ready, cross dock capability, storage......wait a minute....that is me. :) What put you off about the OD thing? Heck, it ain't that bad. I had expected you'd be telling us you were under that overweight load already. Are you having a van day again? I've never been able to make the LTL thing work consistently. Keep in mind mind as a Canadian he has to cross a border so 90% of available freight is gone right off the bat. And what is available never seems to pay enough to cover the DH miles it takes to PU and DEL it. Not to mention the guy who's paying the TL rate wants his stuff ASAP and he won't be too keen on and extra layover to PU and an extra layover to deliver someone else's skids. Remember the meek shall inherit the earth but only when the aggressive are finished with it. |
| All times are GMT -12. The time now is 03:12 AM. |
