You can get decent 2005 and 2006 53' reefers with 7k to 10k hours on them for $23k - $30k (depending on options) if you shop arround. Don't buy junk that you will later regret.
Originally Posted by chris1
(Post 488677)
Depends on how well sealed it is. There will be some water retention and insulation loss. Also if you run to CA it's too old.
Originally Posted by Musicman
(Post 488679)
Originally Posted by TaylorTrucking
(Post 488681)
I didn't know CA had a rear restriction what year a reefer could be what is it?
(Post 488687)
Unit has to meet emission specs no more than 7 years. 2003 is good through 2010,2004-2011 ect.
I was @ a dealer in Olive branch, MS the other week and i was told they have some good deals on 2004 less than 20k. Only thing is the unit has alot of hours as it was used by a team outfit. if all checks out well i may purchase one myself. |
(Post 488675)
would a 99 have the same problems?
These are age related problems. All reefers will develop them eventually but a '99 would almost surely be in better shape than a '90. I just traded in a '98 that was still reasonably solid, but you could tell the insulation had degraded quite a bit and there were soft spots starting to show up in the floor. If you're going to run regionally, you can get by with older equipment that is well maintained. If you're going to run coast to coast it becomes a much bigger gamble. It doesn't sound like you have reefer experience. Tread carefully, the liability risk is much greater. |
Originally Posted by no_worries
(Post 488696)
I have 2 53" REEFERS 2001 GREAT DANE Units looking for to sell or rent them
Both of them are in 100% road ready condition. if interested give me call on 727 776 5991 |
Personally I will never own a refer larger than 48' . The problem w/ shippers is . They need to educated on the difference. Example 44,000# load cannot be loaded past the
48' mark so your hauling around an extra 8' or around 2500# for nothing. If by some SMALL chance thier load is 26 boards @ 44k turn them side ways in a 48 and they fit just fine and tight is better than loose for refer fuel usage. ( the cool or frozen product holds it temp better tight). BTW in the last 30yrs allmost all loads I've in a refer are 18 to 19 boards. In my opinion a 53' is only good as a flat bed or dry van. |
Originally Posted by tazgunny
(Post 489105)
| All times are GMT -12. The time now is 02:54 AM. |
